SET amp power consumption
SSM
17,311
64
Tipoca City
Looking at the power specs for several SET amps. They typically list 250-280w max for 18-25w output. This 'max', is it a uniform consumption regardless of my volume level setting? Or is it possible, when I'm listening to music at lowish sound levels, the amp is actually consuming less than its maximum wattage rating?
Pray enlighten.
SS
SSM
17,311
64
Tipoca City
questions for senior toobheads with vastly more experience...
KT88, EL34/6CA7, 300B, and 845
Which of these reproduce orchestral strings and woodwind the nicest?
SS
SSM
17,311
64
Tipoca City
Virtually none of the SET integrateds I'm looking at offer pre-outs or main-in sockets.
In the insane interest of future upgrades( :wall: ), would I be better off considering SET power amps instead so I can still change or improve the overall sound by swapping toob preamps?
SS
Jazid
4,401
958
Yes. Much better.
Then I would choose speakers that posess the strengths I am after, then choose an amp that has sufficient power and control to work those speakers correctly, then worry about output valve sonics. :)
Sent from my GT-I8190N using Tapatalk
Jazid
4,401
958
Perhaps I should add that if the total budget is modest (sub £1k for example) you moght do better to buy and swap integrateds. The economies of production at this end of the budget scale mean compromises in PSU, casing, and component costs might make the overall quality of an integrated better and you will not have to add the worry of pre - power synergy.
But at the higher end of the budget scale separates are the way to go IMO, just for flexibility in system matching
SSM
17,311
64
Tipoca City
Ta James. I would have about 3 grand to throw away, so it seems like SET separates are the way to go.
I am coming to reckon SET integrateds without pre-outs or main-ins aren't future-proof. Unless their inherent sound quality is that good that it doesn't warrant upgrading!!!
SS
Jazid
4,401
958
Agreed. Also if you are happy with source and speakers (which are the most variable sounding components) then you get much more flexibility in system matching with separate pre and power amps. Also at this kind of expenditure kep an open mind for push pull tube power amps. Their sound is different to SETs but they have undoubted strengths in drive and control. Also a p/p amp around £2k second hand is a top performer whereas you're in middle range SET territory. I am thinking Mac 275, a damn fine amp; Bomb proof and depreciation proof to boot :^
SSM
17,311
64
Tipoca City
I already got two PP toob amps, James, and very superb they are. I am looking to add a SET amp and then I would be a complete audiophool. The only amp I would still be without is a Class D but I don't need such a donkey. :p
cheerSS
HoopsOnToast
Legend Wammer
11,800
582
Oxfordshire
Rob
Cool. Do I wish all SET amps had that consumption rating. :? Can the Zen drive my Tannoys tho', Tannoyboy? ;-)
SS
Rolling back the years there :zip:
No idea, Dave Whitter used to rate the Zen with his Prestige ones.
hearingisbelieving
5,669
219
Bendorf, Germany
Ta James. I would have about 3 grand to throw away, so it seems like SET separates are the way to go. I am coming to reckon SET integrateds without pre-outs or main-ins aren't future-proof. Unless their inherent sound quality is that good that it doesn't warrant upgrading!!!
SS
SS, the Audio Note Oto SE has pre-outs. Not sure what you mean by main-ins? Is that so you can connect a different pre and bypass the onboard pre? If so, it wouldnt take much to configure the Oto as such - literally just moving three wires about two inches.
The Oto SE sounds sublime when partnered with appropriate speakers and although rated at only 10watts, subjectively, it seems much much more powerful than my 50w class D amp. It produces music with much more body and the bass is fuller and more controlled - as well as just sounding more "right".
rmsshipbroker
5,599
156
Yorkshire
Steve
Hi, not read the thread yet but just a quick point.
Some Oto SE's do have pre-outs but not all, mine doesn't for example.
Something to check for specifically if you were interested in that model. :)
Cheers
Steve
P.S. I really like mine. :love:
hearingisbelieving
5,669
219
Bendorf, Germany
Hi, not read the thread yet but just a quick point.Some Oto SE's do have pre-outs but not all, mine doesn't for example.
Cheers
Steve
Very cheap and easy to install pre-outs Steve if you ever wanted them so I wouldnt let it hold anyone back from buying one of these
AmDismal
9,324
134
For £3k, you could wait for a pair of Unison Smart 845 monoblocks to come up. They are rare, but often go for well under that. Odd, really, as the S8 and S9 go for the same kinda money, despite being considerably lower down the range.
Vinyl Art
12,480
191
Good post by AmDismal. IOf you are going to run those Tanoys off a SET then a good quality SET is the order of the day. I've used both a 300b SET (NAF 18W) and a 211 SET (AirTight) to goood effect. Lower powered SETs would struglle with Tanoys (IMHO). Also worth considering the Icon Audio 845/805 amps.
Kinchitshaw
