SOLD - TEAC AI-501DA AMP/DAC.Headphone Amp
Membership Upgrades
yorksmark
150
7
Huddersfield,
Mark
The Teac is in like new condition and will come with original box, manual, power cord and remote. This little box of tricks with it's great retro styling originally sold for £699. The feature VU meters on the front panel can be dimmed using the remote.
Full specifications from website are:
Maximum Output Power 90 + 90 W (4 Ω, 20 to 20 kHz) / 45 + 45 W (8 Ω, 20 to 20 kHz)
Output Power Rated: 60 + 60 W (4 Ω, 20 to 20 kHz) / 30 + 30 W (8 Ω, 20 to 20 kHz)
Impedance Supported: 4 to 8 Ω
Total Harmonic Distortion 0.05% (1 kHz, 4 Ω, 55 W)
Line In 100 dB (IHF-A)
Frequency Range 10 Hz to 60 kHz (-3 dB)
Digital Audio Inputs
Coaxial 1 x RCA jack (0.5 Vpp / 75 Ω)
Sampling Frequency 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz
Bit Rates 16- / 24-bit
Optical 2 x Optical digital connectors (-24.0 to -14.5 dBm peak)
USB 1 x type B connector (USB 2.0 compliant)
Bit Rates 16 / 24-bit
Analog Audio Outputs
RCA 2
Nominal Input Level -10 dBV
Maximum Input Level 6 dBV
Headphone Output
Connector Standard 6.3 mm stereo jack
Maximum Output Level 50 + 50 mW or more (32 Ω, THD+N 0.1%)
Power Supply 120 VAC, 60 Hz
Power Consumption 55 W (Maximum)
10 W (Idling mode)
0.2 W (Power-saving standby mode)
Operating Temperature 41 to 95˚F (5 to 35˚C)
Operating Humidity 5 to 85% (no condensation)
Storage Temperature -4 to 131˚F (-20 to 55˚C)
Overall Dimensions (WxHxD) 11.4 x 3.2 x 10.4" (290.0 x 81.2 x 264.0 mm)
Net Weight 8.81 lb (4.00 kg)
Price £250 including postage
