Just had a partial update from OTA, apparently, pcb component problems are very very rare and the only thing to make the spark arrestor kick in and shut things down is a panel problem. > :nerves:Whilst I'm not a DIYer, I still have my own problem to resolve. One of my 989s has developed an intermitant fault in that the right channel briefly cuts out. Sometime for half a second sometimes for upto 3 seconds, it may do it just the once or 5 - 6 times on the trot. I between times there is no sound degradation and the whole system sound great. Will nurse them through my next BO on 09/02 then it's yot another 320 round trip to OTA, so will leave it with them and pick up on the way to Keggy on the 14th. Hopefully not to expensive as Steve reckons it could be a dry joint making the protection circuit kick in..... Or it could be another panel, Arrgh!
That's a pain in theJust had a partial update from OTA, apparently, pcb component problems are very very rare and the only thing to make the spark arrestor kick in and shut things down is a panel problem. > :nerves:
Having taken both speakers up this time they have removed All 12 panels, and then using the best 6 reassembled 1 fully working speaker. The remaining 6 panels are going to be checked over the next couple of days to see which one/ones need fettling. I should hopecully have a final, cost of repair for Monday or Tuesday (if its a bass panel gone then my arse is covered as it will be an FOC warranty job) but I get the feeling caviar and wagu beef is off the menu for a while, but at least I know they will be fit for duty intime for Keggy.
Proper 'wam at its best' :notworthy:@bencat
Andrew would you like me to bring my pair of Cambridge A50s (Stan Curtis era) power amps, they can be run as stereo or bridged mono, just incase you have a problem on the day? I have plenty of room as am borrowing the works van for the weekend.
John a very kind thought but I would not use anyone elses equipment with my propensity to have things go boom . I can get annoyed and swear when it is my own kit but would be mortified if i destroyed anyone elses .@bencat
Bet I could still find a way.We could start a short circuit proof amps thread, there must be some
Octave valve amps have built in protection, they demo at shows by shorting the speaker cables.We could start a short circuit proof amps thread, there must be some
Ah, 'hopefully'. One relatively short word that is asking for trouble4th IcePower amp now constructed so I now have a separate amp channel per driver. Hopefully the last of the modifications before the show!
