I’m looking to send my speakers for upgrade. and I need a fair amount of 50mm stratocell foam to put in the crates I’m building. Does anyone know of a reasonable supplier?
Thanks.
Thanks.
They will not accept anything other than 50mm stratocell
I have, they put two forward yesterday. I have yet to get a quote from either. I’m just trying to get the most reasonable as I will have to dispose of it all when it comes back to me.
They won’t accept thatHow about a few sheets of this
https://www.diy.com/departments/jab...ation-board-l-2-4m-w-1-2m-t-50mm/26818_BQ.prd
Tackleberry is actually trying to get his speakers fixed by ATC so that’s not going to help.Tell them to jog on then!
It might be worth finding a local company that either makes packaging or receives packaged goods,.to see if you can get some off cuts of stratocell. Maybe drive around the local industrial estates?I’m looking to send my speakers for upgrade. and I need a fair amount of 50mm stratocell foam to put in the crates I’m building. Does anyone know of a reasonable supplier?
Thanks.
