This is the way to go if you are intending spending a lot on the arm and cartridge. If you are going to keep all to a budget then turntables like Thorens, Systemdek, Goldring GL75 and others can turn in a superlative performance with the right arm and cartridge for the former and cartridge for the Goldrings. For example a Rega with an ortofon black or similar MM or a decent Moving Coil will IMO easily outperform a deck costing ten times as much with say an ortofon Red or Blue or similar.Vinyl is always the area you can quite easily blow your budget.
think order of priorities
Deck... greatest cost, then arm then cartridge
not sure what your budget is? Were you thinking new or used? Btw, vinyl is addictive
The thing is with turntables I am convinced there is the placebo affect where because something is pure eye candy you think it sounds better (because you want it to sound better). However, nice as a Girodeck looks IMO in outright performance it does not exceed that of a second hand LP12 or Systemdek Heavyweight purchased for less than half that you will pay for the Girdodeck ... then of course their are Rock turntables that can be had for a very good price second hand etc etc
