the best speaker cable?
G
what's the best speaker cable out thereunder £30 a metre? i'm thinking of a change(had my qed for 7 years now) must not be to bright.
E
earl of sodbury
I've yet to hear better than this:
Supra Ply 3.4/S shielded speaker cable, £8.10/M here:
http://www.digi-shop.co.uk/shop/default.html
You may find it cheaper in Sweden, given that it's made there - there are a range of cheaper and similar-performing cables they make - the Classic 4mm at £3.60/M is probably more than good enough - I just like the idea of shielded cables!
The conductors are tinned - so no oxidation (copper) or tarnishing (silver) to reduce conductivity over time -a fit and forget option.
And all come in a very attractive "electric" blue sheath - high WAF I found.
I use the PLY 3.4/S in my main system and Classic 2.5 in my second system - both sound far better than the hateful QED I used before!
HTHs, churz, eofs
G
Duvet wrote:
Anything by VDH . Your current faves i know;)
no van den hul thank,s but the supralooks good sodbury i'll search it out cheers for that one!
technobear
Ursine Wammer
2,679
104
Glastonbury, UK
Until the last week I've been using QED Silver Anniversary. It suited my previous systems (Arcam/Mission, Arcam/ATC/Castle) but it doesn't suit the current Arcam/ATC/Dynaudio setup. It's a bit too hard and stark and bright.
So now I'm using this:
http://www.maplin.co.uk/Module.aspx?ModuleNo=13295&doy=7m10D
It's from Vandamme. I'm using the 4mm version and very good it is too. It hasn't taken anything away from what I love about the Dynaudios but it is definitely less hard, stark and bright. Just enough to restore a natural balance to the sound.
The only real problem is that it's cheap so most of you will disregard it. That's a shame.
E
earl of sodbury
technobear wrote:
Until the last week I've been using QED Silver Anniversary. It suited my previous systems (Arcam/Mission, Arcam/ATC/Castle) but it doesn't suit the current Arcam/ATC/Dynaudio setup. It's a bit too hard and stark and bright.So now I'm using this:
Good stuff Van Damme, if you want straightforward copper cable, you can't beat it - not the slightest point paying a penny more...
Their website sells direct and has a few more options than Maplins stock: http://www.vdctrading.com/content.asp?SubsectionID=30
churz, eofs
Polarbear
Old bear
9,581
403
PB
Chris, Has anyone told you ther is already a white bear on here :dude:
technobear
Ursine Wammer
2,679
104
Glastonbury, UK
Well I never! So there is!
Wonder if we're related
It's the same avatar I use on all my other forums
Polarbear
Old bear
9,581
403
PB
Daddy! :raoflmfao:
Polarbear
Old bear
9,581
403
PB
PB was here first and is known everywhere as PB:fight:
Kinchitshaw
