Turntable break in
flaxton
519
71
58
barry vale of glamor
I have just purchased a brand new Rega 6 with a new Goldring 1042 cartridge. Will I notice any change in sound as it breaks in or is this just a myth. Thanks.
tackleberry
3,155
Leeds..
You will notice the 1042 break in, but depends how you have it set up now It sounds very different head up/head down
Gray
501
456
Just my own view, but I think way too much credibility is given to the issue of 'burn-in'.
Not saying there would be none (especially with electro-mechanicals such as carts and speakers), but I think 'brain burn-in' explains more of the perceived differences as people get used to new sounds.
Reactions: kernow
tackleberry
3,155
Leeds..
Absolutely.
OP.
It’s a good cart, setup right, it sounds very good. I don’t have any experience of the arm you have though.
DUVET
Administrator
2,721
8,167
Middle
Carts do bed in from experience and that's not expectation bias from my POV . Had some take 20 hours other take up to 80 hrs . So don't doubt your set up. The sweet spot sort of arrives .
Reactions: eddie-baby
DUVET
Administrator
2,721
8,167
Middle
Might be worth renaming the topic to "Cartridge break-in"...
With turntables most are soak tested for 48 hours or so before being packed and shipped so can't imagine any bedding in time .So agree with the above .
kernow
6,932
2,128
Devon
Shaun
I fully believe transducers break in, but not any more than 100hrs or whatever, as for kit itself.. ehh
tackleberry
3,155
Leeds..
I’d be less concerned about about things settling in, Just good setup. I messed around with the tone arm height a fair bit, I found a big difference. Get the bass and top end how you like it and leave it!
Lawrence001
4,310
1,818
133
Lawrence
I'd only thought of stylus/cart/tonearm cable break/burn in before but is it possible that initial use could benefit a TT mechanically? Any roughness in the spindle/bearing(/motor even?) could be worn down (more likely at the budget end) and the whole thing might settle into the plinth/onto the feet with the weight, especially after shipping or just slight intolerances in the manufacturing process.
kernow
6,932
2,128
Devon
Shaun
Interesting you think about that after tonearm cable. I wouldn't call any mechanical device burning in, might take an hour to settle or whatever. It's obvious with carts and speakers from new
And . Would likely be inaudible
Southeastern
The '59 Sound
1,000
891
South East
Tonearm cable - definitely will need burn in.
After purchase, I sent mine back to Analogue Seduction for a free burn in for a couple of weeks, and the issue I had with it before I did vanished.
However. Cardas cables are known to require long burn in periods, I just didnt think it was too much of a concern, until I was swapping things here and there trying to wonder why everything sounded a bit muffled since installing. After burn-in, that muffle was completely eradicated and its now spot on.
Lawrence001
4,310
1,818
133
Lawrence
I said break in rather than burn in, rather like speaker driver surrounds from new.
Reactions: kernow
mac72
1,275
771
Shenfield, Essex
Slav
Goldring 1042 requires as little capacitive loading as possible also use short low capacitance tonearm cable , this one for example is 35pF/m plus connections:
https://www.shop.back-promo.co.uk/Silvercord/p4417238_16800086.aspx
Goldring could sound bit bright if you exceed 150pF total tonearm internal wiring +tonearm cable + phono stage input capacitance as the peak in FR caused by electrical resonance approaches hearing range but yes transducers do break-in or bed-in and it could be between 50-100 hours , most likely VTA would change slightly but nothing to worry about as record thickness variation would make more difference .
mx2one
