Turntable break in
kernow
6,932
2,128
Devon
Shaun
I believe that anything with moving parts is going to bed in, carts and speakers up to whatever many hours depending on what they are with an audible difference, how ever small or large. Things like turntable motors and bearings, you probably wouldn't notice and it wouldn't take very long. My turntable sounded on point straight out of the box and although used, well who knows how it "sounds" because it's dependent on 3 million other factors, kit, cart arm etc
Reactions: Colinjg
Blzebub
Thundering bigot
2,102
1,272
Stamford, Lincs
I'd only thought of stylus/cart/tonearm cable break/burn in before but is it possible that initial use could benefit a TT mechanically? Any roughness in the spindle/bearing(/motor even?) could be worn down (more likely at the budget end)
From an owners' manual:
"The Model 30/2 precision turntable is partly run-in before leaving the factory but will further benefit from the first few weeks of use. Do not worry if initially the bearing is not totally silent. A slight ‘swish’ barely audible at very close range in a silent room will quickly disappear if the machine is left running continuously, one month is recommended."
uzzy
Grumpy Old Git
8,087
3,908
NN38TA Northampton
All I know is I sent one of my Decca's off to be retipped .. that requires a new armature so in effect a new cartridge (think new cantilever and suspension in a MM or MC cartridge) .. when it came back I slotted it in in place of its identical brother that is half way through its life and ,,, no difference to my ears.
Perhaps they change a bit in time or perhaps they don't ... I have to say I very sceptical that there is any "major" change and as for the "subtle changes" one has to ask, is it a change or our ears just getting used a different cartridge or arm etc.
karma67
163
172
63
brighton
jamie
leave it running for 1 month! christ how tight are the bearings when new?
mx2one
