WD-40
JJCharles
77
London, , United Kin
Would WD-40 be any good to solve a scratchy volume control?
JJ
E
Effem
WD-40 only provides a very short cure and after that it leaves a horrid sticky residue that collects fluff and muck very quickly
Use a proper switch cleaner available from Maplins or try your local TV repair shop for a tin of it
E
earl of sodbury
Yeah, that Servisol Super 10 Dik Dolan linked to is great stuff. Also good on plugged contacts (interconnects, mains, etc.) of all types, cleans and maintains a good contact for ages - even seems to stop silver tarnishing
Just keep it off anything you plan to solder...
churz, eofs
Beobloke
7,135
2,848
Adam
WD40 is great as a lubricant and cleaner for mechanical linkages (most of my old Garrard turntables would never have moved again without it
), but as it's an insulator, it's a BAD idea for volume controls.
'nother vote for Servisol here.........
penance
3,903
11
Disappearing up my o
), but as it's an insulator, it's a BAD idea for volume controls.'nother vote for Servisol here.........
It is an awful lubricant, it is infact a Water Dispersant.
Beobloke
7,135
2,848
Adam
:wall:
:wall:
Beobloke
7,135
2,848
Adam
Well, last time i checked the best water dispersant was oil-based. Oils generally make quite good lubricants.
There is also the small matter of "LUBRICATES" writ large upon the tin.
And the fact that if you take a siezed automatic mechanism on....oooooh, say...a Garrard deck, spray it with WD40 and work it a bit, it miraculously frees up and starts moving again.
And the fact that if you spray some down a stiff lock, the key turns much more easily.
I could go on but you probably get the point.......
penance
3,903
11
Yea, but its crap at all those, it atracts dirt, dries quickly and is to thin to offer any long term lubrication. Like Plusgas, it is good for freeing siezed parts but not for long term lubrication.
I could go on, but you get the idea.
kengxx
