This is a plug on one end of a linear power supply cable - I believe these are quite common:
I'm trying to find a cable that has this connector on one end and a USB-C on the other end - to hook up a Raspberry Pi 4. For some reason I'm not having any luck, and part of the problem is that I don't know if this two-pin connector has a name. The only ones I've found so far are advertised by Chinese sellers on eBay, but not with USB connectors - and they simply call them "two pin cable for linear power supply", which doesn't really help the search engines.
Any clue where I'd f ind a cable like that, or what the correct search term should be?
If this doesn't go anywhere I might rig my own and bypass the USB connector, but ... alternatively, is there a "barrel to USB-C" converter? So many questions, so little time
