xDuoo TA-20 Balanced Tube 12AU7 Headphone Amplifier. I bought this directly from the xDuoo store on 12th April. Very nice headphone amp when paired with my LSA HP-3 (= Kennerton Magni) headphones. I'm only selling now as I have a vintage preamp (Yamaha CX2000) arriving soon which has a headphone socket, and this will be enough for my needs. I rarely listen to music through headphones.
This will come with the stock valves (unused), and the original box. Location = Colchester. Price = £250 + £12 postage to mainland UK.
The TA-20 won an award from Headfonia for best headphone amp of 2019. I have copied the text below from the Headfonia website.
Best Amplifier
Tube: xDuoo TA-20
The xDuoo TA-20 takes what made the TA-10 a great amp, to the higher ground. It can drive virtually any headphone you like, or want, with a sound stage much wider than its transistor competitors. True, it’s not a full Tube amp, but that’s also what makes the TA-20 affordable (and compact).
Build quality is still astounding, with real attention to details and a comprehensive layout. It’s not the most transparent amp you can get, but that’s the magic. If you’ve never had a tube amp before, maybe this should be your first one, even more, if you own a planar headphone.
Spec. of xDuoo TA-20
Best Amplifier
Tube: xDuoo TA-20
- Anti-interference aluminum alloy shell
- Removable aluminum alloy tube guardrail
- Dual 12AU7 tube
- Class-A transistor expansion
- Customized hi-fi capacitor
- Professional volume IC
- Balanced input and output
- 2 sets of aux input interfaces
- Power supply: External electricity (AC100–240V)
- Output power: Phone: 2,000 mW (32 ohms); XLR: 2,000 mW (32 ohms)
- Frequency response: 10 Hz–100 kHz (+/- 1 dB)
- Gain: +18 dB
- Distortion: ≤ 0.01% (1 kHz, 32-ohm load)
- Signal-to-noise ratio: 115 dB
- Headphone impedance: 8–600 ohms
- Footprint: 5.8 x 8.3 in (14.8 x 21 cm)
- Weight: 3.4 lbs (1.55 kg)
