Sub bass & bass Speakers with 18" Volt RV4564 drivers
MF 1000
Interesting the comments here on secondary vibration of the baffle.  My speakers have a concrete baffle to overcome this issue. Details here
https://sites.google.com/site/matteisloudspeakers/home
I agree with the principle/idea Dave …hence my heavily braced 51mm thick mdf/balau (vv dense hardwood) sandwich construction on the cabinets
  • Upvote 2
That makes sense; making a bass cabinet "hard" moves the resonant frequencies above its operating range.
Edited by tuga
Quite a few years ago I recall reading an article about speaker panel vibration/flexure which discussed the idea that even a tiny movement in any of the panels when stead across the area of the panel was equivalent to the more significant displacement in the speaker driver over an obviously smaller area.  This I guess is what we refer to a colouration in a speaker.
As far as my bass units are concerned it’s amazing that even with a 100 mm port the 18” driver creates quite a pressure inside it and forces air through any small gaps in the inner carcass and the cladding…..so if the cabinet wasn’t braced and of a thick sidewall etc  I’m sure I’d have far more vibration occurring.  Just writing this has got me thinking and I might now feed a pipe through the port length and set up a basic manometer to gauge the internal pressure created.
A manonmeter will just show atmospheric pressure I think, due to averaging out the rapidly fluctuating pressure of the acoustic waves. Using your microphone would be the better way to go if you were really curious.
  • Upvote 3
One of the most hardcore money no object approaches to cabinet design I’ve seen so far is that of Rockport:
images?q=tbn:ANd9GcRCxQaduyMkQCxVTuYPYn-
Edited by tuga
  • Like 3
  • Moderator
Absolutely - it won't give you any useful info. A mic is the way to go.
With a 25Hz tone through the driver I can feel air escaping through a couple of panel gaps ….these will be filled/sealed as I now have time before March 22.
I wasn’t suggesting that a pressure test could replace any other testing …..it was just out of my image curiosity to see how much pressure was created inside the cabinet to generate the air escaping from orifices other than the port - this has to be created by a pressure differential and they must have detrimental effect.
Edited by MF 1000
Interesting. And a bargain at only $169,500 a pair for the Lyras :shock:.
  • Haha 2
£200k in GB... :D
I wasn’t suggesting that a pressure test could replace any other testing …..it was just out of my image curiosity to see how much pressure was created inside the cabinet to generate the air escaping from orifices other than the port - they must have detrimental effect.
I was suggesting using a microphone to measure the pressure inside the speaker cabinet, by actually putting it inside the speaker. Although you might find the pressure levels exceed the maximum the micophone can be used for.
Edited by MartinC
Oh, and at the risk of pointing out the obvious, be very cautious about playing about with tones at this sort of frequency as it's a good way to burn out a driver if you're not careful.
I had a quick look but couldn't find anyone selling them!
Are these guys in your vicinity?
https://audiolounge.co.uk/brand/rockport-technologies/
  • 1 month later...
Julian - Bigrod gave me some great advice on finishes for the yellow balau, using tung oil so this weekend I decided to start on the hopefully final surface finish.  As you may recall it’s a tropical hardwood vv dense (30% more than Russian birch ply) with a very tight grain structure.
Trying to produce each panel from 140mm planks with biscuit joints etc was a challenge and the wood has ‘moved’/ cupped so I found a vintage Wolf belt sander off eBay than had the grunt to attack this wood.
Two hours of sanding with 80 and 120 grit belts gave me a good flat surface and then as recommended by Julian, I hand sanded it down to 400 grit then a tack rag (to remove all the dust), wipe down with white spirit, then using a lint free cloth applied a 50/50 mix of pure tung oil & white spirit.
Wow the grain really stands out now …but this morning I flatted it off again and applied a 75/25 mix.  I’ll let this harden off for two weeks (mainly as I’m away with work next weekend) then it’s two more coats of 100% pure tung oil.
  • Like 6
  • Upvote 2
