Cable Monkey
Simple and cheap entry into networked audio...
I can see applications where the OP origional post maybe an advantage for some folk with particular requirements but cant help think it a bit nonsensical to go to all the per lava for a newbie configuring a Pi running the SharePort AirPlay emulator when you can pick up 3rd gen apple tv with proper airplay that roon recognises as a end point and comes with codecs that support a wide range of audio and video formats for £40 and have the real deal plus all the additional features the apple tv gives in a plug and play device.  If not a roon user you still have usb and optical out which can be fed to a to dac for networking using airplay or casting apps.
Picking up old Apple devices isn’t really a sustainable solution but I do actually have an old Apple TV. I’ve no idea what generation it is but I’ll plug it in and see what it does. I already know what it doesn’t do!
I'm just setting up to explore Roon myself only yesterday I installed Roon Rock on a Intel Nuc just have a couple of bios settings to configure and add some codex and it should be fully up and running.
Looking forward to giving it a try.
I’ve been using it for a while and I am an unapologetic fan. Have fun with it and let us know how you get on.
The beta of RopieeeXL now has Spotify support added. Use Spotify Connect to control it.
Edited by Cable Monkey
I came back to RoPieeeXL  as a result of another thread
The install is still a lengthy process but the software has improved and matured quite a bit.:)
Switching between Squeezelite and Spotify/Airplay is now much better
It is almost plug and play for someone with a little experience (I still needed the start-up guide) but a brave beginner will probably get there without too much effort.
I don't know about Squeezelite and DSD as I only have three test files and there is something wrong with my LMS install that I can't be bothered to resolve o.O
There are no user parts to fiddle with, so if one wants a standard Squeezelite Player, Airplay, UPnP and Spotify it might be worth trying.
ronnie
  • Upvote 2
I’ve been running it (RoPieeeXL) for a few weeks now, using Spotify Connect and DLNA and have found it to be really stable. I’ve messed around with it a bit to alter the endpoint names “advertised” - they reflect the location and amplifier source rather than the host name. I believe this functionality will be exposed through the UI in an upcoming release. The best part is it supports gapless playback with Spotify.
I had been using Moode, but it’s still missing gapless Spotify playback, but that’s pretty much the only negative. That functionality  should be coming soon.
Appears to be fixed, but I haven't tried it
https://www.diyaudio.com/forums/pc-based/271811-moode-audio-player-raspberry-pi-1507.html#post6284707
I was able to rename the player through the gui :)
The main reason for me at least is I will not have any Apple products at used in my house or system . The full reasons for this are not really relevant to this thread so will skip them . My main reason here is that all Apple products are closed and if something changes then they are difficult if not impossible to change or add to . Raspberry Pi has infinite ways that it can be altered and change it is the veritable blank canvas and with a download and flash to an SD card it can be changed , updated altered and added to .
