Sign in to follow this
dicy
Help with digitising vinyl
Hi All
I have quite a few LP’s which are not available on any other format and I’d like to record them and upload to the NAS.
I used to have a lovely little Roland Cakewalk UA-1G which made this task a breeze, but I have turned the house upside down and cannot find it, I reckon I must have lent it to somebody?
Anyway, I’ve placed an ad for a rega fono mini or something similar, but nothing so far and nothing about on eBay for the budget. I really can’t afford to spend much more money, who knows what’ll happen in this strange new world.
So, my question is this - is it possible to use the tape outs on my amp (I have a marantz pm-4 and a A&R A60, so both have phono stages and tape outs) and feed into one of the cheaper behringer line only audio interfaces and then to the laptop via usb?
If so, how good would the quality be (I think I still have vinyl studio somewhere) and I assume that my dynavector 10x5 would be fine?
Cheers
Rich
Edited by dicy
Whichever way you get the signal to your laptop the software to use for recording, editing etc is Audacity.
Open source costs £0.00 and is amazingly versatile and updated regularly.
I've used it for years.
I think the easiest way is to use the microphone input on the lappy, which is what I used before USB was invented. I still have some of those conversions, I think you will be pleasantly surprised. Just make sure you set the record level as high as possible without compressing.
On 29/03/2020 at 23:53, dicy said:
Hi All
Cheers
Rich
If your budget allows Rich, this would do the job:
https://www.bax-shop.co.uk/audio-converter/art-usbphonoplus-ps-analogue-and-digital-audio-interface
As well as its built-in phono stage, it can take line-level sources and send them via USB to computer.
This means that using tape out from your amps is also an option (as well as recording from any other line source).
I suggest you then compare the Art, Marantz and A&R phono stages and choose the best for your permanent digits.
The Art is also a headphone amp as well and has other in/outs, making it quite a versatile interface.
Even comes with Audacity software on a disc (though that's easy enough to download)
Here's the manual. The block diagram on page 7 (which needs rotation) shows what it can do:
https://artproaudio.com/framework/uploads/2018/06/om_usbphonoplusps.pdf
Edited by Gray
I used (and still have) one of these ... they are only £70 new and can be used to record at 24-bit / 96kHz quality. Afterwards it can be repurposed as a headphone amp or DAC.
https://uk.creative.com/p/sound-blaster/sound-blaster-digital-music-premium-hd
Edited by t1no
I just had a look at the ASR review of this, and Amir couldn't get it to work properly.  How is yours?
It worked for me at the time, a few years ago now. I ripped about 120 albums and singles before I got rid of my turntable. It was mainly an archiving exercise and it seemed more than ok for this purpose. The headphone output was ok for my AKG headphones. The supplied software to edit, clean and normalise the recorded WAV files was actually pretty good too and much easier to use than Audacity.
I use Roxio Easy VHS to DVD converter it works with Audio too
https://www.roxio.com/en/products/easy-vhs-to-dvd/standard/
