firefuocco 95 Posted December 9, 2020 I am on a bit of a project with my old LP12. While the Valhalla is up at Class A getting sorted I am going through a few other issues. I have done a swing test on the Basik Plus and get about 10 return swings with the last few very small. I also did a test I saw on youtube holding the arm post at a table edge and carefully moving the antiskate arm rest and watching for sticking in the tonearm that should be vertical. I get two small sticky movements. What effect will the bearing issues be having on the SQ? I haven't noticed any SQ problem. Is some type of lubrication possible or does it require new bearings? Who can fix the bearings? Audio Origami? Anyone else? Thanks for he advice & I'm sorry if this is all covered a lot. Share this post Link to post Share on other sites
Mr Kandid 280 Posted December 10, 2020 (edited) Any servicing or repair to that arm now would need a third party dealer to do now as LINN won't entertain a repair now. Might be worth contacting a well established dealer and ask if they might have a pre enjoyed in their spares department that might work out more cost effective than a lengthy repair. I would phone CYMBIOSIS for advise no point browsing the website as they have tons of gear not listed. https://www.cymbiosis.com/ Edited December 10, 2020 by Mr Kandid 1 Share this post Link to post Share on other sites
DavidHB 1,474 Posted December 10, 2020 I don't imagine that there is too much of a call for second hand Basik Plus arms these days, though one in good nick can still give the Pro-ject arm formerly fitted to the Majik LP12 a run for its money. It is just possible that Chris at Hidden Systems (https://www.hiddensystems.co.uk) will still have my old Basik Plus, which was still in good shape when I upgraded. David Share this post Link to post Share on other sites
DebsE 115 Posted December 10, 2020 6 hours ago, DavidHB said: I don't imagine that there is too much of a call for second hand Basik Plus arms these days. You'd be surprised. 1 2 Share this post Link to post Share on other sites
akamatsu 1,421 Posted December 10, 2020 If you can find a Majik tonearm (Jelco) at a dealership somewhere, it might be a very good value, a used one from someone who has upgraded. It might be more cost effective (SQ/cost) than repairing the Basik Plus. 1 Share this post Link to post Share on other sites
DavidHB 1,474 Posted December 10, 2020 1 hour ago, DebsE said: You'd be surprised. Well, that's something on which it would be nice to be wrong. David 1 Share this post Link to post Share on other sites
firefuocco 95 Posted December 10, 2020 Thanks for the replies which I will follow up on. For a start I am trying with adding some lubrication to see what happens. Nothing to lose. I realise it isn't a long term solution. Share this post Link to post Share on other sites
sktn77a 118 Posted December 10, 2020 21 hours ago, firefuocco said: I have done a swing test on the Basik Plus and get about 10 return swings with the last few very small. I also did a test I saw on youtube holding the arm post at a table edge and carefully moving the antiskate arm rest and watching for sticking in the tonearm that should be vertical. I get two small sticky movements. Could be two things: 1. Brindled bearings/races - not much you can do about this if the races are shot (and if the bearings are bad, the races usually are, too). 2. Gunk buildup (grease/dirt) over the the last 30+ years. Spraying a little WD40 in the bearings might clean them out some. If that improves the swing then a more through dowsing with WD40 and then addition of a little oil might do the trick. I wouldn't do this with a better/newer arm, but it sounds like it's pretty much ready for the dumpster as it stands. Share this post Link to post Share on other sites
Mr Kandid 280 Posted December 10, 2020 As said above. Share this post Link to post Share on other sites
firefuocco 95 Posted December 11, 2020 I had GT85 on hand. It is like WD40 but with PTFE. I put some on last night and this morning the swing number has doubled to about 19 - 20 return swings. I am now going to order a small bottle of super fine watch oil. Share this post Link to post Share on other sites
