FS Norma Audio REVO IPA-140 with DAC Mint Condition
CrillboBaggins
I’ll definitely regret this but for sale is my Norma Audio REVO IPA-140 in Silver with the DAC module (140w/8 Ohm).
A well regarded integrated amplifier with stunning looks as well in my opinion. I’ve had a change of circumstances so it’s either my deck or this amp and as I have an old Denon amp this unfortunately has to go.
In perfect working order without a single mark and all original packaging.
This unit was built in Oct 2018 and is nearly two and a half years old and carries a further two and a half year warranty. I’ve never had a single problem with it.
The remote does have a slight nick to it and I’ve tried to show this in the photo but it doesn’t affect how it works and is just cosmetic.
This one has the built in DAC (24/192khz USB) and retails at  £6,244.
I’m after £3,600 but open to offers.
Collection preferred (Stockport) but can send by courier, meet within a reasonable distance. Courier costs excluded buyer to arrange and accept risk / responsibility.
Lots of reviews on-line, gutted to see it go. EDCC0028-9275-4E9D-86F7-2A868F6318B8.jpeg.b3f0a96154869512ad41eef7649edf09.jpeg
Gain
34 dB
Frequency Response
0 Hz - 1.8 MHz (-3dB, not filtered )
Output Power (8 Ohms)
140 W RMS
Output Power (4 Ohms)
280 W RMS
Inputs
4 RCA, 1 XLR Balanced, 1 USB DAC
Outputs
Dimensions (H x W x D)
110mm x 430mm x 365mm
Weight - Unit
25 K
Features:
Extreme low noise, high speed schematic topology and wide band  ( >2 MHz ).
High current MOS-FET power device (150 A output peak current).
12 power device for a total rated 1.500 W power handling capability.
Separate power supply for Gain, Driver and Output stage.
High speed and  low noise regulated power supply for gain and driver stage.
High filtering capacity  (70.000 uF) with numerous (24) low impedance capacitors.
Full aluminium non-magnetic frame.
Toroidal power transformer specially designed for audio applications.
Input configurable as Direct Inputs, for Home Theatre use
Outputs configurable as Pre Out, Active or Passive, for use with Power Amp and/or with Active Subwoofer
XLR balaced input
Remote control of all functions with NORMA RC-4 remote control.
Two speed volume control (Fine and Fast).
24/192khz DAC board module.
Protection for DC signal sensitive loudspeakers.
Inputs selection by relay with GOLD/PALLADIUM contacts.
RCA solid core gold plated plug connector for any signal connections.
Stand by mode switches off the microprocessor one the command is executed, so as to limit interference on analogue signal.
Edited by CrillboBaggins
Price dropped
This is an absolutely stunning amplifier, best amp I’ve owned by some way (and there’ve been a few) - superb sound and wonderful build quality.  Will drive virtually any speaker, good at low volume, very organic sound, etc. Checkout the reviews here:
https://www.hifidelityuk.co.uk/reviews
The on-board dac is not bad too.  At this price a bargain. 🙂
Cheers
I agree, it’s like a work of art when you take the top off and look inside.
I have the lower powered Norma IPA 70, an absolutely fabulous amplifier. With the lid removed, it looks like a Metropolis inside - beautiful build quality. Having owned many beautiful amplifiers, it’s NOT going anywhere! I can only imagine what the higher powered IPA 140 sounds like! There’s a very good review of The IPA 140 in the current issue of HI FI Plus by Alan Sircom. Check it out folks and good luck with the sale.
Edited by marko
Just out of interest what's the rrp?
It says £6,244 in the advert.
wonderful , chris kelly who does harbeth room at bristol did a review in hi fi critic . lots of people seem to like it . when the tax man stops harrassing me with penalties i will try one !!! in the meantime someone is in for  a treat
I’ve looked into a courier and I think fully insured would be about £80 which I’m willing to include in the price.
This is a superb amplifier. In all seriousness, someone should buy this quickly!’
Yes - seriously reference-class amplifier.  A real steal at this price with £3k off list.  (I have no connection with seller, but a strong one with my own Norma 140! 😊)
Could do with selling this sooner rather than later so if anyone is genuinely interested then please make an offer.
I don’t want to give it away by any means and do appreciate it’s a lot of money to spend.
thanks
Luke
