Selekt DSM with no cartridges, Akurate system hub (2018 Variant), Klimax Exakt DSM (2013 Variant)
How would you rank these three system hubs and which would be your choice as an upgrade step from AEDSM (2014 Variant)?
Is the Klimax hub of any version still significantly better than the last version of Akurate or Select?
Edited by rduras
How would you rank this three system hubs and which would be your choice as an upgrade step from AEDSM (2014 Variant)?
Is the Klimax hub of any versions still significantly better than the last version of Akurate or Select?
Klimax is significantly better.
Yes the Klimax 2018 is significantly better I would still rate the 2013 as better
Thanks for sharing.
The difference between Klimax Exakt DSM (2013 Variant) and Klimax Exakt DSM (2016 Variant) should be only HDMI 2.0 and in Klimax System Hub (2018 Variant) there is a new PCB version.
So, the expected difference in sound between the first two variants should be minimal if any, and if one does not need HDMI 2.0 the 2013 Variant is probably a better SH buy because prices should be somewhat more affordable.
  • Like 3
