antiskating settings for adikt
Hi guys,
With counterweight set at 1.75 gr, what is the general consensus for value setting of the antiskating for an adikt. Actualy I've set it at 2 for testing but not sure it is the best position yet.
Many thanks for experiences. In my otherwise linn system I use a thorens td2001 with tp 90 and adikt.
Many thanks
I'm not sure on a Thorens TP90 as I haven't worked on one for a while.  I would start at 1.75 and then try plus or minus .5 gram and go from there.  If 1.7 is worse but 1.8 is better then keep going in that direction until it gets worse.  You are looking for the most musical and focused perfromance.  I find good vocals make it easiest to hear for me.  I wouldn't be surprised if you end up at 1.9 or 2 as I think the calibration on the Thorens arms was a bit on the low side.  But agian it has been a while since I worked on one and I don't recall working on one with an Adikt.
