Linn Espek active configuration links
igor_tarasoff
That’s right. From the ninka days I remember it being that the outside card needs to correspond to the function you plan to use.
Sent from my iPad using Tapatalk
  • 2 months later...
Hello.
Can someone explain how the config card actually work?
I have been considering upgrading my Aktiv Keileidhs to Aktiv Espek and I am confused about what is going on here. The Keileidhs required internal modification. I understand the Espeks do not. Are the cards just a visual guide or is there some form of electical connections built in? Thanks
Robbie
Hi - I suspected they were just a visual guide back when I had Espeks, as different configurations meant using different connectors. However, the manual seems to suggest there’s circuitry:-
Mick
2 hours ago, robbiegrant said:
Hello.
Robbie
The internal passive crossovers have multiple connections.  The external cards that are swapped around to change the configurations have a printed circuit board inside that changes which of the passive crossover connections are "bridged".  The external cards are passive (no components) but they are a fundamental part of the circuitry/connections.  If you lay tham about 30 deg to the horizontal, you'll be able to see the tracks that create the connections.
`I've often wondered about whether the card acted as a guide or whether it was 'tracked'. The instruction is to lay the unwanted card below the selected card - do none of the printed tracks on the buried card interfere with the selected connectors then? I've never really paid any attention to the orientation of the buried card, but perhaps I should?
This makes total sense. Thank you.
Onwards in my search for a nice pair of Espeks and the associated Aktiv cards for my LK140's
Thanks again
Robbie
You need both the outer and inner cards to complete the circuits. I experimented with just one card and was rewarded with silence.
  • Upvote 2
I've had my Espeks now since around 2008 and have used quite a variety of amplification, passive and active, with them: Kairn+Klout passive bi-amped; AV5103+4200+2200 active; Kinos+KCT passive biwired; and now passive single wired with Lejonklou Boazu. My current configuration is much more musical than any of the other configurations I have lived with.
Thanks! -  that is interesting.
Yes, I once heard Espeks, passive, with a single Solo on each and they were stunning.
good tip
