linn Radio and Jazz not working
switched on yesterday and neither the Linn Radio or the Jazz stations will work but the classical station does work. Anyone else got this? I should add I use an Akurate DS. All other stations work as well including Tunein.
Edited by OldLinn
Yes. I can’t access those channels either. Must be an error in the other end. Linn Classical is working though.
I think I tried all three two days ago here in Taiwan, and none worked. I don't know if I've ever tried to use them, so I put it down to it being geofenced here in Taiwan. Are you all in the UK?
Nope. I’m in Sweden, Europe.
Unfortunately, here in the Netherlands Linn Jazz and Linn Radio are also not available.
Strangely enough, they can be listened to via OnlineRadioBox on
https://onlineradiobox.com/uk/linnjazz/?cs=uk.linnjazz&played=1&lang=en
They work fine for me (UK) via Roon, but not if I use Kazoo, so it’s possibly a TuneIn issue.
Mick
It looks like a Linn problem then so I will contact them in the morning but they will probably be aware.
MickC I don't have them on Tunein just the Radio icon.
Thanks for your responses.
Edited by OldLinn
I am but dont know about the others.
Mick
I should have said I am using Kazoo but it's strange you can hear them on Roon but I can't.
I *think* (and happy to be proved wrong!) that if they’re under ‘Radio’ in Kazoo, which is where I tried, they’re from TuneIn. The Radio selection simply shows the favourites from whichever TuneIn account you’re using; if you’ve not set anything up on TuneIn it’s probably the Linn account.
Mick
Ah well I reported it and very soon it was all on again.
Edited by OldLinn
Mick
I did find them eventually on Tunein but they didn't work there either. My account was fine but it wasnt just me who couldn't hear.
Thanks for your help and support, glad it's working again (in the Netherland that is)
How very strange and a week later the three stations are working but there is no visual on any of the icons. Its been like this all day.
Edited by OldLinn
