Akurate to Klimax Exakt hub for 530 ?
I have an Akurate Exakt hub + 530 system. I can upgrade it with a second hand Klimax Hub.  Is there a real musical advantage to be hoped for with this setup?  I would like to upgrade my system.  A priori katalyst is still not planned on the 530. Thank you for your feedback.
I’ll doubt that. But others will turn up claiming that it will 🙂. However, if the second hand Klimax Hub is from a dealer you should have the possibility to try it out your self before buying.
I believe the advice to listen, if you can, is a good one. If you are not able to compare and you are not buying from a dealer - then you would need to consider the 'vintages' of the two pieces of equipment.
If you are looking to replace roughly like-with-like (date-wise eg. 2016 with 2016) then I would always recommend that the Klimax sounds better than the Akurate version and would likely to be a worthwhile upgrade. If you were replacing a later ASH with an earlier KSH then I would suggest not. It is also worth considering whether either pieces of equipment still retain any of Linn's 5 year warranty. This would be important for me if I were to purchase outside of the dealer network.
42 minutes ago, Gilangelugo said:
My system is from 2016 and the proposed Klimax hub is also from this year.
I will probably have to do a comparative listening at the official dealer.  the Klimax is on deposit.
The Klimax will be better.
Know someone who has just done the same.
A friend of mine bought 520s after I had raved about them.  He was waiting for a traded in KEDSM andbought a late Akurate Exakt DSM to tide him over.  He got the KEDSM last week and found it to be far superior and is now selling the Akurate.
I have run 520s and recently 530s - bothsystems were brilliant.
If you can afford it and find one, Iwould recommend a 2018 variant KEDSM.
9 minutes ago, Gilangelugo said:
this is the 2016 version that is offered to me at an attractive price.  how is the 2018 version better?  is it possible to upgrade the Klimax?
I replaced my 2017 with a new KEDSM in 2020 which was obviously a 2018 variant.  The 2018 variant I belive had new surface mount technology and I found it a sigificant upgrade.  Butnote that I was blown away by how good 520/530s were with my pre 2018 variant.
The later version would cost a lot more assuming you can find one.
Do you mean the KSH? From linn docs it looks like the KEDSM/1 was a 2016-2108 varian and was replaced by the Klimax system hub. The KEDSM/0 is the pre 2016 variant.
Adsm/3 >> Akurate 4200/1 >> Tukans (Silvers/K400)
This is what I should've done when I had 530s. In retrospect, moving from Akurate hub to Klimax hub should've happened before going to Akubariks.
I am referring to KDSMs that only have Exakt outputs.  I have not kept track of what Linn call them !
  • Upvote 2
Do you know what updates i need to make to be up to the current klimax?
The only way to update a Klimax Exakt hub to the current version is to buy the latest version referred to as the next generation Klimax Exakt Hub.  £15 K !
Linn do not offer the ability to upgade say a 2016 variant to the 2018 version. The only way to do it is to replace the 2016 variant with a 2018 variant.
8 hours ago, Flatcoat said:
Currently this is correct. Gilad did say he wanted to offer upgrades for the "classic" Klimax within a year of NG launch.
Even if / when it happens it might not include the hub and it will likely be a compromise compared to NG products due to space constraints.
Edited by sunbeamgls
