FS: NVA Balanced Mains Distribution Box
TheMooN
Normal domestic UK mains is single ended. This unit alters the incoming mains to a balanced topology resulting in a removal of noise and distortion inherent with much of the UK mains quality. Depending on how ‘Dirty’ your mains quality is this unit will lower the noise floor of your attached HiFi equipment resulting in an enhanced listening experience, particularly effective powering source equipment.
This was a special order from NVA , Comprising an all- acrylic NVA bespoke case containing a UK Spec 230W  1KVA balanced mains transformer feeding 4 X audio quality unswitched and non fused Schuko receptacles and a 10 Meter power lead... The unit will be supplied with a UK Mains plug.
********** THIS UNIT MUST USE A UK SPEC 13 AMP *FUSED* MAINS PLUG TO CONNECT TO A MAINS WALL SOCKET **********
********** DO NOT EXCEDE TOTAL POWER DRAW ON THE 1 KVA RATED BALANCED TRANSFORMER **********
 Never used other than to test continuity.
Imaculate condition.
£425 Bank transfer or PP Gift Or cash on collection London E11
This is a heavy unit therefore Postage + £25
Origional NVA factory box and packaging.
Dimensions Of BMU- w350mm x h140mm x d290mm
Edited by TheMooN
  • TheMooN changed the title to FS: NVA Balanced Mains Distribution Box
Could you give any details of construction, filters , earthing , dc blocker, that sort of thing, thanks
