My DIY 4 way speaker system
Bokke
Over the last few months I've been on a learning journey. Things that seem so simple now were difficult to get my head around. Thanks to @MF 1000 @tuga @newlash09 @Tony_J @bencat @Psilonaught @MartinC @cooky1257
@greybeard
@Shadders
@steve 57
@eddie-baby @lindsayt
if I've missed any out then sorry
So now I'm ready to build
this thread will show you the equipment and progress
stand by
Edited by Bokke
  • Like 3
  • Upvote 4
stand by
Excellent sir :)
Wishing you all the very best :)
Good luck, and enjoy the journey.
4 hours ago, eddie-baby said:
OK thanks look forward to seeing what you come up with and your thoughts on it.
Just arrived
@cooky1257 monacor lol stageline my ass. What a tip off
Thanks againIMG-20211027-WA0010.thumb.jpeg.1c713e12cd1c077632d98c5f0a68d748.jpeg
  • Like 3
  • Moderator
Drawings and driver specs would be good...:^
  • Upvote 2
You may want to keep the drivers to yourself until you've bought them, if you're buying them off ebay. You don't want to be competing against anyone else when you bid for stuff.
Are you aiming for high efficiency speakers? By high, over 96 dbs / 2.83v @ 1 metre.
Or medium efficiency, approx 93 dbs?
Or low efficiency, below 90 dbs?
id say medium
sensitivity (db/watt/m) 94 bass, 94 midrange
tweeter low at 91
Will you be going large for the woofer? 18" or bigger? For lower distortion on bass transients at generous volumes? Or will you be keeping it smaller in order to make it more domestically acceptable?
The tweeter seems low in efficiency. Tweeters tend to be more efficient than the other drivers. Padding them down is OK. Are there any alternative tweeters that would fit in with your design and that you know sound good that are in the 94 db plus range?
