Vinyl Clear out Sale
AJSki2fly
Hello,
Thanks for looking, I don't post much on WAM although I have been on here for a while, I am better known on a couple of other forums, I will be adding and removing form the list as time passes so keep checking.
My vinyl collection needs a prune as it is getting out of control, so below is what I currently have to offer.
I have priced each as fairly as possible, based lower than current sales values on Disccogs and Ebay. All the records will have been cleaned, most with an ultrasonic record cleaner, then rinsed with pure water and vacuum dried. A few will have been manually cleaned with L'Art Du Son, pure water rinsed and vacuumed dry. Each will come in a protective clear sleeve and will be carefully packaged.
Nearly all have been played once using either a Benz Micro MC or Goldring 2500 MI cartridge by myself and graded accordingly, a few have been visually graded, I follow the Discogs guidelines for grading and if in doubt grade down. I will visually check before sending records out. If you have any questions on records or sleeves please ask.
POSTAGE and packaging:-
Packacking will whenever possible will be in a LP mailer or I will make a suitable one from cardboard to protect the contents.
All packages in the UK will be sent 1st class signed for, please note that in the UK Small Parcel is 45cm long,  35cm wide and 16cm thick, up to 1kg cost is £4.85, and up to 2kg is £6.57. So to get value for money it is best to purchase several records together.
For larger purchases or if sending abroad I will advise the total cost and method of sending which may be cheaper by a courier such as UPS.
If you are interested in purchasing any of these records then please note which in this thread and then PM me, I will then contact you and advise the total cost and how to make payment.
Thanks for looking,
Adrian
Click here to see list of records available in google spreadsheet
here is the link as I noticed clicking on the above does not always work, not for me anyway, so you can copy and paste if need be.
https://docs.google.com/spreadsheets/d/e/2PACX-1vQ7IF-BTiev-nic3a5Cr8-q39rfhifOTsVMQ1gNoOnLXDSjnN2qZY01Dr3KJAeIusCRZTs3SUozvbI-/pubhtml?gid=0&single=true
Edited by AJSki2fly
fix link problem
6 more records added to the list, with some comments and dates added column
Just marked some more as sold, will soon be adding some others today, keep an eye out.
Added two Led Zeppelin albums, and a Pink Floyd
Removed Rainbow - Down to Earth, added Rainbow Rising
2 hours ago, TIU said:
PM sent re Meddle.
Hi, PF - Meddle is marked as SOLD STP, and I just sent you a PM.
Thanks
Can l take the two Fifth Dimension albums and 78 in the shade please Sir.🙂
A note to say buy from Adrian with complete confidence. My LP was posted promptly, reliably and received 'in perfect working order'.
