£2k System for classical music
JamPal
Content Provider
32,265
552
Sussex, West Side
Following piano mans thread. I started thinking about what he could do if he went second hand.
So forum weekend challenge, scour the classifieds, dealer web sites, hififirsale, bargain corners.. etc etc and build piano man a second hand system that would do his (relativley) big room and classical tastes justice.
JamPal
Content Provider
32,265
552
Sussex, West Side
Mine would be as follows:
Opera Callas SP from http://www.ukd.co.uk bargain corner £1175.00
Musical Fidelity A308 integrated amp from Ant in the classifieds. £850.00
Stick with current CD player. Save for a Rega Apollo.
Matt J
13,193
67
Not Derbyshire
Sugden A21 (£500 ish), new pair of Stirling V2's (£750 ish) meridian 508.24 (£700 ish) a pair of stands and a few of the decent cheap no bull shit cables that have cropped up, Van Damme/Gotham etc.
HectorHughMunro
5,628
1,642
London, , United Kin
I'd suggest Spendor BC1 or SP1 (£180 and £350 for good ones), Meridian 557 (£750), Meridian 501 (£350), Denon 2900 (£180) and go for 'Something Solid' stands. Musical Fidelity Nuvista or VDH D102 MK 3 interconnect and Cat5e speaker cable.
Also, a Quad FM3 or Armstrong 623 for the Proms.
yoda900
4,004
258
163
Cheshire
Kef Reference 3.2 on hifi for sale £1600 in black
Nad Silverline out of the classifieds
Bit over budget but before haggling.
Keep CD player.
Would fill a big room with the scale required for classical.
technobear
Ursine Wammer
2,688
111
Glastonbury, UK
The Dynaudio Contour 1.1 is good with big scale orchestral classical. Ask EofS what he thought when I treated him to some Mussorgsky. He kept looking for the sub
The Triangles are pretty good too but do show up rough recordings. If the recording is good then the Triangles can sound pretty realistic for the money.
The Strat
14,024
130
123
Buckingham, UK
Lindsay
I reckon I'd go for a Rega CDP (I think I prefer over the Naim at the lower price level)/Naim Nait 5i/Dyn Contour 1.3s - would do all genres brilliantly imo.
The Strat
14,024
130
123
Buckingham, UK
Lindsay
Having said all that Dudy's Regas look a brilliant buy at the moment.
Jezzer
Passionate
9,811
1,195
Uxbridge
Jezzer
Meridian 507 or 508 - £5-£700 on Fleabay/hififorsale
Harman Kardon HK 680 - can be had for around £250 from Ebay.de
Dynaudio Contour 1.8's in the classifieds at £900.
JamPal
Content Provider
32,265
552
Sussex, West Side
Keep CD player.
And that NAD amp is a doozy... Darren nearly had to wrestle it from me.
AmDismal
9,324
134
I listen to about 90% classical in a similar size room (slightly bigger, high ceilings), so I would naturally recommend my system!
Certainly the EAR amp and Living Voice speakers can be found for about £800 each, which leaves £400 on source - I'd go for a Squeezebox, possibly with a DAC, but YMMV. Get a SB+ or Transporter later
The great thing about a Squeezebox for classical music is that it liberates you from the strictures of the CD. I have a box set of Mahler symphonies, and it's all over the place - half of the symphonies are split across discs, unlistenable. However, with some simple tagging, suddenly I can listen uninterrupted to a whole symphony. Ditto for opera on multiple discs and discs where there are several different pieces.
But anyway, the key point is that a SET plus high sensitivity speakers is not out of this budget, and it does sound nice!
Adam
OpenSea_0
