I haven't seen one cjr, but I'd like to see it on a latest generationHD plasma against a more modern premiumupscaling progressive player with HDMI (Such as an ArcamDV135 or a Denon 3930), because it's difficult to believe. DVD has really moved on in most ways, and the reasonthings like the 9500go so cheap is because they don't have those things which are now standard on £100 DVD players (which give generallyexcellent performance). The case for buying older premium models is that (to me) the tend to give richer and more vivid colours, but are often not quite as sharp, focused or good with panning that newer, cheaper more technologically advanced players are. At least not on a big HD screen.Great if you're sticking with CRT for a while though!
Also worth consideration is that the W series 40" is true HD (1920x1080), and pretty much any SD signal looks grainy and blurred. Upscaling and HDMI should help significantly in counteracting this (as far as possible). I think upscaling is much more critical on a DVD player for your TV than it is for'standard' resolution (1366x768)HD panels.
Nontheless, as a wise man said above, HD is the way to go if you're thinking of spending any seriousmoney.It's not like SACD vs CD where differences are often marginal and diffcult to demonstrate (withouta very serious setup):HDvideo isclearly anddemonstrably superior to SD videoin every sense. Personally I wouldn't spend more than £100 on a new standalone DVD player, even if my screen cost £6k and I had 1000 DVDs. Buying the Tosh HD-DVD player as recommended above would be a better buy for <£500 (which will play and upscale your normal DVDs well too!). Having said that, my choice would be the Panasonic Blu Ray (or a PS3).
