£3-4k upgrade opportunity?
Nativebon
MUZIC FIRST
1,200
968
London UK
Ian
It's a continuing source of bafflement to me why people with a well known penchant for changing and fiddling with things are asking others why they want to change gear.
Were you unhappy with your system before your last change, or the one before that?
No, I thought not.
You just fancied seeing if things could get even better.
That definitely seems to be the idea behind the OP imo.
Your right that's the idea, but with more info and specifics, others may be in better position to advice how to enact change to better sq for OP.
Reactions: tuga
DomT
7,818
5,557
Ericeira Portugal
Dom
No, I thought not.
If we don’t understand what is behind the decision how can we offer helpful advice.
Already someone has said streamer and DAC and someone else said speakers. My gut says a better amp. But unless we have some sort of idea of the OP’s problem to solve it’s all rather meaningless.
Reactions: Sotosound
34,289
No, I thought not.
For me, the question was simply to get some idea as to what to suggest changing, not as to whether or not anyone 'should'.
If it was mine, and my money, I'd change the amp first. If it was you, probably the speakers. But what to change depends on what the aim is. Surprisingly, there are some people who don't just want to change things for the hell of it :ROFLMAO:
DUVET
Administrator
3,074
9,718
Middle
This isn't a must its an opportunity and they are different things . The OP may be perfectly happy with his system and is just asking for some opinions and it's what forums are about and we do have a tendency to over think things in response to questions like these. Your system is mighty fine but missing vinyl . ;)
Reactions: Soundsinheaven
Soundsinheaven
239
15
38
Awbridge
Neil
I have the Venere 2.5 as well and think you would need to spend considerably more than 3-4k to get a significant upgrade. I'm looking into the possibility of upgrading the crossovers though.
That's exactly what I thought! I love the look of the speakers but just want more. Is it GR research Crossover upgrade your interested in??
Soundsinheaven
239
15
38
Awbridge
Neil
To many people this would be an end game system. So the best place to start with is to ask what is it that you are not happy with?
It's not I am unhappy I want audio navara, to experience the next level of hifi fildelity. Understanding what people think is the weakest link and take it to the next level.
Soundsinheaven
239
15
38
Awbridge
Neil
Thanks for your comments, spot on but vinyl not for me I'm afraid.
Reactions: Rayymondo
DomT
7,818
5,557
Ericeira Portugal
Dom
In which case change your amp but go secondhand. I found that whilst there is a difference between DACs, I own DACs by Benchmark, Luxman, Auralic, Yamaha, and Audient, there is a bigger difference when you jump up to a much better amp. I used to own an Audio Research LS25 mk2 and VS115 but the valve heat was a problem in Spain and my wife was too scared to use it. So I bought a Marantz PM11S2 that has served me for the last ten years. It has seen off a lot of other S/S amps including the Marantz PM10 and NuVista 800 (I used to own a NuVista M3). These amps were different rather than better. Then last year I bought another Audio Research SP17 and D130 (s/s power amp). It’s a big leap ahead and I saved a fortune by going secondhand. At the time I also home demoed an Accuphase E380 that was a step up from the Marantz. At a dealer I also listened to the Krell 300 which was excellent and on par with the Accuphase and Audio Research.
Soundsinheaven
239
15
38
Awbridge
Neil
My gut says your right about the amplifier and speakers, (the amp Gato Audio dia 250) mighty and fast this class D amp is , I think I could do with more warmth and more realism
No real problems with the speaker's but was just thinking they could be holding the system back? Have been thinking of a crossover upgrade from GR research?
cotes-du-rhone
38
30
23
West Yorks
I still think that to get a significant upgrade, you need to spend between 3 and 10 times the original component cost, unless there is something significantly wrong. The OP doesn’t suggest that. £4K will buy something like what he has now. It may be different, he may like it better, but it’s unlikely to be an upgrade. Upgrading your relationship with your significant other on the other hand…😍
34,289
Now we're getting somewhere.
You want 'warmth and realism'? The Fabers will do it. The Gato probably won't. Some people love 'em, and I understand why. Not that I agree. I've only heard one once, and I thought it brittle and thin sounding.
Sonus Faber and valves are a classic combination. BUT... they do need some current, and the 'warm and cuddly' horrible valve sound won't work well at all. I'd keep everything else (any change to the DAC and streamer will make relatively small differences that you may well hate) and play with borrowing/auditioning some amp combinations. Ideally, either poweful but 'tight' valve integrated, or valve pre and class-A solid-state power amps. I can't find the link at the moment, but there's a Pass Labs intergrated somewhere that may just work ideally.
Lawrence001
4,568
2,092
168
Lawrence
  • Haha
Reactions: TheFlash and rabski
Jules_S
Are we there yet?
2,207
Southampton
Jules
Not often I disagree with you, Guru Rab, but I will this time. As an ex-owner I think the Gato is anything but thin sounding, I found it very even-handed and without any obvious emphasis. But then again I think Living Voice are hateful, shouty things so what do I know? 🤣🤣 Shows how much we all differ in our preferences!
That said, I would probably have thought that something like a Pass Labs would bring out the best in SF speakers.
  • Haha
Reactions: rabski
CnoEvil
Legend Wammer
9,163
8,494
Northern Ireland
As somebody with that Gato Amp - you might try it with Harbeth (or similar BBC design). IMO. They work very well together and should give both warmth and realism (especially for acoustic/Classical/Jazz)
34,289
Amp + speakers though.
I've heard a Gato with ATC and to me it sounded overly 'clean' to the extent of being thin and lifeless. But then much as I love them, the LVs are incredibly amp sensitive too. If you make it to the October show, you can see what mine are like with a goodly bit of 845 magic and a fast sub (which makes more difference than some may expect).
I suspect that Gato + Sonus is not an ideal mix.
julesd68
687
31
58
Julian
Yes that's what made me think about it - his views on improving cabinet rigidity were also interesting. I'm not unhappy with the speakers in the least, quite the opposite, but worth investigating if one can squeeze a bit more from them ...
per gunnar
