Hi
I have an Icon Audio Stereo 25 which I have fitted with Gold Lion KT88s - I bought some PSVANE UK-6SN7s to replace the chinese ones with but to me they sound a bit dull, by mistake I put in some Sylvannia 6SL7GTs and they sound much fuller and brighter. The manual says it's ok to run them for testing purposes and no harm will come of it. But doesn't say if you can run them long term. I've checked the Bias Voltage on the KT88s and it is ok and within the specified range on each valve.
So my questions are - can i continue to run them without damaging anything or would a pair of TungSol 6SN7GTB give me a better more open with better treble and bass - or are there other valves that will give me the sort of sound I am looking for?
The front end is a Linn Sondek with Rega Exact cartridge fed into Yaqin Phono Stage and GoldLion 12AX7s - speakers are B&O S45-2 until I can get my Beovox M100-2s out of storage.
