I propose to produce a 4 way version of the 5-way system (see a 5-Way Horn System thread) which has sufficiently less 'real estate' to enable both transport and installation in other venues than a home, whilst retaining much of the SQ and SPL capability of the bigger system.
One goal is to demonstrate a fully balanced, active horn system (not a hybrid) at the next Wam Show.
This system will use equipment that is already on hand in the 5-Way set up or alternative equipment collected on the way that could have been used in that system.
For example, I can lift the tops (1.5" JBL 2435Be, + supertweeter),, which are on a platform straight off the frames at home and secure them to a fresh support system.
And I can utilise a pair of Trapezoidal cabinets that house twin 15" drivers that I have been storing for several years, together with the 4 JBL2225J drivers for them, that have also accompanied me from flat to flat.
I have become accustomed to and have been working towards balanced systems for a number of years now and my smaller record fair system is also balanced. I could 'borrow' my balanced phono stage from that system and match it up with my recently returned Django passive TVC pre amp (thanks Jessica_k), that will pass to my Ashly 4 way 4001 active analogue crossover and on to 4 amps (3 valve for mids and tops and a muscle amp for the bass).
It should be movable and relatively versatile regarding room size, (or hall size).
Needless to say the front end will be a vinyl player ( I can choose from several).
An exciting project for me and, hopefully, one which will attract paying customers at the show as well as giving members a unique taste of what horns can do.
Jack NSM
This thread will chronicle the assembly of the system with all the twists and turns you might expect, plus some snaps of the work as it progresses.
Jack NSM
