Hi chaps,
I did a thread last year re. ES14 spkr replacement ideas, the thread then went on an interesting new tangent exploring instead, putting in new tweeters. FatMarley & eddie-baby very helpful, my thanks again to them.
I tried falcon who said he'd ask a designer for the tweeter spec, to choose a new seas type of theirs ( was the recommended idea). No reply, tried a few times. Forget that then.
Going back over the thread & as long @ 12 pages.. I need a fresh start. Crack on with something.
@Fatmarley mentioned he had some monacor tweets, type: https://www.ebay.co.uk/itm/125353700897?ssPageName=STRK:MEBIDX:IT&fromMakeTrack=true
As these very affordable, & looking at the baffle design ( mdf plate, holes in), I now think I could make a new plate. 9mm birch ply > router, 30mm centre hole, bit of fettling. And just have a go. If it doesn't work out plan B) try some seas ones mentioned on the other thread. Plan C) put it all back as it was!
I just want to check, ideally with FatM, if there's anything I've missed before having a try with these Monacors?
Thanks for reading my drivel, Abbot.
