At £425 a pair these are great little speakers, especially when space is at a premium
http://www.audiologica.co.uk/acoustic_energy/301.html
01403 336 339
Versatile, modern and compact, the 301.
With its front slot port the 301 offers great flexibility with positioning, sounding fantastic and fitting comfortably anywhere in your home.
The 301 is the most compact member of the 3-Series, measuring just 300 x 185 x 250 mm (HxWxD) yet still retains the clean, powerful, articulate sound. With minimal distortion and resonance the 301 will offer you supreme clarity and cohesion wherever it is placed.
Type: 2-Way Reflex Slot-Loaded
HF Driver: 28mm Custom AE design fabric dome
LF/MF Driver: 110mm Spun, hard-anodised aluminium cone
Cabinet: Braced 18mm MDF Carcass
Frequency Response: 48Hz - 32kHz +/- 3dB
Power Handling: 150 Watts RMS
Amplifier Compatibility: 25-150 Watts into 8 Ohms (Recommended)
Nominal Impedence: 8 Ohms (6 Ohm minimum)
Sensitivity: 87dB for 1 Watt at 1 Metre
Dimensions: 300 x 185 x 250mm(HxWxD)
Weight: 5.5 kg (Single speaker, unpacked)
Finishes: High gloss piano black or white.
01403 336 339
