The time has come to sell my Acoustic Solid Wood turntable. This comes with a Rega arm collar and Rega RB250 tonearm. A silent performer and with adjustable speed control that is absolutely solid when set on the controller. I've used this with the Audiomods Series 6 tonearm to great effect. See the info below for more details, be warned this is a heavy beast!
Looking for £1400 collected from Plymouth or plus post (arranged by buyer). I have the original packaging so postage won't be an issue.
The Acoustic Solid | Solid Wood is designed in the classical style and is a more robustly constructed version of our Classic Wood model. It uses a heavy 60mm thick aluminium platter running on our precision "zero tolerance" bearing. This is mounted on to a solid 76mm thick MDF plinth, which is finished with a cherry veneer. The platter is string-driven by a separately housed synchronous motor, powered by our microprocessor controlled supply unit. The platter is fitted with a mat made from natural leather, topped with a 5mm thick acrylic layer. The unit is supported on three independently adjustable feet.
The Acoustic Solid Solid Wood provides further bass extension due to its greater mass. Stereo imaging, resolution of fine detail and dynamics are all to a very high standard. Music is reproduced with a flow that is the essence of the real thing.
Specifications:
Platter: 60mm thick aluminium machined from a single billet
Mat: Natural leather with a 5mm thick acrylic layer
Motor type: Synchronous
Drive: String-drive by a separately housed motor
Control: Microprocessor controlled power supply
Feet: Three individually adjustable feet
Chassis: 76mm thick MDF with cherry veneer
Dimensions: 470mm W x 250mm H x 370mm D
Weight: Approx 35kg
Specifications:
Weight: Approx 35kg
