I must have had the tales and pictures of Scalford's communal mega-horn system in the back of my mind when I asked Armin Krauss of Avantgarde Acoustic whether my trusty old Duos would be improved with fully active operation, halfway expecting him to laugh the idea away. Unfortunately, he didn't, stating that getting rid of passive crossover components in front of driver units was always a good idea, as particularly capacitors tend to do nasty things no matter how you implement them - in fact, they had planned to bring an advanced active crossover for their horns to Munich, but ultimately other projects such as the Zero One took priority (rightly so, I'd say).
Anyway, the only passive crossover components in my Duos sit in the pathway to the high frequency unit, a 12 dB/octave with the crossover point @ 2,000 Hz. The mids are directly driven by the amplifier and of course, the bass is active already, with both level and crossover frequency variable.
So in fact, fully active operation of the Duos in its simplest for would mean a separate amp for the highs with a low pass in front of it.
Ideally, the amp for the midrange horn would also have a low pass crossover in front of it, but that would mean driving the internal amp for the subs directly from another separate preamp output instead of from the amp speaker terminals - which as we've seen is rather tricky because of the huge impedance the line input sees (i.e. the same as the speaker level input, which is designed to minimise current demand from the main amp). So to start with, I'd just bi-wire the midrange horns and subwoofers from the speaker outputs of my 2A3 SET, and add a true flea power with reduced bandwidth for the HF horns.
An Elektro Mekano S6 has been suggested as a power triode for the HF amp, giving about 2W with relative ease.
So - what about the output transformer? What sort of bandwidth would be needed for this specific task, given the 2 KHz crossover point? What sort of overall layout and components when tailoring the performance for this application? Am I right in saying this could be done, and done properly, relatively cheaply? Any 'gotchas'?
