Adjustable,adhesive hifi feet for a turntable
gasolin
1,266
201
Denmark
Adjustable hifi feet for my turntable
May for easy of use be some adhesive rubber or foam feet,pads you just add another to adjust the height
Cheap and from a european store, give me your best bid
bigrod
Super Wammer .. Pussy 🐈 lover
5,521
7,662
D H LAWRENCE TOWN
Julian
They are absolutely brilliant, back in the day 40 + years ago I remember lots of these as replacements for the standard feet on Turntables .
They used to invert them and use the screw holes to attach to the turntable and then drill out the centre of small carpet protectors that were put under furniture legs and screw through the bottom into the anti vibration device..
Reactions: lostwin
bigrod
5,521
7,662
D H LAWRENCE TOWN
Julian
All sprayed black the looked great and did a good job .
Dungtran
