My AR ES-1 has a wooden cabinet/plinth, the corners of which are supported/braced on the underside by a short length of wood at each corner. Also at each corner, a simple rubber foot is mounted under the table via a wood screw up into this wooden brace.
I'm now going to be placing the turntable on a surface that isn't itself adjustable (unlike the turntable shelf on my old rack), so levelling the table will be a bit difficult (because the feet aren't adjustable). I've seen lots of after-market adjustable isolation feet, but they seem to be based on an M6 or M8 bolt, so presumably they'll be anchored into a piece of kit that has the correct nut secured into the component's base.
Does anyone know of an adjustable isolation foot that can be anchored by a wood screw?
