advice on a quality "Rangefinder" - Fuji X-Pro 1???
pmac
14,252
298
Looking to buy a rangefinder type camera, but before we go any further, a Leica M9 is way over budget! :nup:
Must haves
Full manual (as well as auto) operation
Large sensor
Very good PQ at high ISO settings
High quality prime lenses available
Easily implemented exposure compensation
Robust construction
Need not have
Video
Scene recognition bollox
I aim to use this for everyday photography, but in particular for travel pics and (non-flash) indoor shots (including for example, hi-fi shows)
I have a Lumix G3 which I use for wildlife photography and I'm quite happy with that, but I want to carry that with the 100-300mm zoom (almost) permanently fitted (200-600mm 35mm equivalent) and carry the rangefinder for high quality landscape and people shots.
Up to now the Fuji x-Pro 1 looks like it ticks most of the boxes and is just within budget. Probably combined with the 18mm f2 OR the 35mm f1.4 Fujinon lens. (I really just want one prime lens at the moment)
http://www.digitalrev.com/product/fujifilm-x-pro1/MTAwMDI1NA_A_A?googlebase=1&country=GB&gclid=CNa9ttnBmLoCFY7HtAodQF0ApQ
Any others out there that I need to consider in that price bracket?
Any advice appreciated!
HoopsOnToast
Legend Wammer
11,821
654
Oxfordshire
Rob
The X-Pro1 is the only rangefinder at that price is it not?
Only other ones are the Fuji X100 and X100s AFAIK.
S/H Epsom R-D1?
HoopsOnToast
Legend Wammer
11,821
654
Oxfordshire
Rob
AFAIK, the Fuji X-Pro and X100 are the only rangefinder cameras on the market other than the Leica.
You can get a 'rangefinder' style compact system camera with electronic viewfinders like the other Fuji X-E1, Sony NEX 6 or 7 for example.
pmac
14,252
298
AFAIK, the Fuji X-Pro and X100 are the only rangefinder cameras on the market other than the Leica.You can get a 'rangefinder' style compact system camera with electronic viewfinders like the other Fuji X-E1, Sony NEX 6 or 7 for example.
Thanks Rob, I guess there's little choice then
fordy
2,427
312
Wirral, UK
Carl
I can thoroughly recommend the X-Pro. I am loving mine and cannot put it down. It's got me out and about every weekend and traveling more frequently, just to take pics. Probably 3-4000 frames since August. I like the 35 much more than the 18 so far although i think my favourite lenses are the 55-200 and the 14. The 35 stays on as the everyday lens though because it's so versatile and is perfect for low light bokeh-tastic shots of the kids in restaurants and cafes where you wouldn't want to use flash.
X-Pro will be replaced next year though so more price drops to come yet. If you can live with just the EVF (and I must say I'm rarely using the OVF so far) the X-E1 is a good option. It's heavily discounted just now too because of the imminent announcement of the X-E2 this week.
35,160
Was at a friend's wedding recently and the pros were using an X-Pro as well as 'conventional' 5D Canons. The guy reckoned the X was a real gem and having had a quick play with it, it certainly felt 'right' if that makes sense. When budget permits, I'm seriously considering one to replace the trusted Canon compact, as it's getting a bit old in the tooth now.
karlinamillion
3,704
309
Londinium
Karl
The Fuji X100 & X100s are fantastic cameras, they feel & behave like a proper camera & the X100 can be hade for a good price too, but, as per the above, they are fixed 35mm lenes, though you can get a wide angle converter.
pmac
14,252
298
Sounds like the X-pro 1 then.
I do want the lenses to be interchangeable and also want the OVF, so I guess it's a no-brainer.
Seems to be very highly thought of, both here and in the reviews I've read.
Just need to choose between the 18mm f2 or the 35mm f1.4. I like the thought of the faster 35mm lens, but the wider angle 18mm may be more of an advantage :dunno: Eventually I'll probably get both, but for now, which one?
35,160
It's APS-C sensor size, but depends on the type of photography you do. For me even the 18mm might not be wide enough, and the 35mm would be no-go. f2 isn't that tight and the IQ means it's better to crop something too wide, that not get enough in in the first place.
pmac
14,252
298
Pretty much my thoughts, so even though I wouldn't mind having the faster lens, I think the 18mm will be the better "all-rounder" to begin with :^
pmac
14,252
298
That's it then, order placed for X-Pro 1 & 18mm f2 Lens :^
Thanks for your help!
35,160
I do love the DSLR, but I have thought more than once that the convenience, size and weight of something like the X-Pro is a perfect solution. So many times I end up sticking the crap compact in my pocket, because lugging around the 50D and a couple of lenses is simply too much damned effort.
Will be very, very interested to see the results!
pmac
14,252
298
I do love the DSLR, but I have thought more than once that the convenience, size and weight of something like the X-Pro is a perfect solution. So many times I end up sticking the crap compact in my pocket, because lugging around the 50D and a couple of lenses is simply too much damned effort.Will be very, very interested to see the results!
Will certainly post some results Richard :^
If you want, I could email high-res images to you?
tkimages
10,548
8,511
St Helens
Tillman
I feel the same sometimes ( it's an age thing in my case) and the Olympus EPl 2, as good as it is, is just lacking that bit of IQ.
35,160
I know. The trouble is, the additional (welcome) IQ I'd get from the EOS is offset by the fact that I simply don't have it, because it's too damned bulky and heavy.
We went to Norfolk to see mother a couple of weekends back and I carefully packed the full kit in the boot. Everywhere we went the weather was glorious, but to be honest what with maps, phone, glasses, wallet, etc. I just left the bloody thing in the car as it was too much hassle.
These days, the DSLR comes out to play when I go out on my own with the sole intent of taking pictures. Which, with business and personal stuff is once in a blue moon. So that's a very good DSLR with three very good lenses, filters, tripod, etc. all sitting in a bag and getting used no more than once a moth at the moment, if that.
I did for a while seriously look at a D5, but these days the thought of a smaller, lighter high IQ solution that doesn't cost Leica money is very, very tempting...
Gromit
7,556
6,717
Yellowbellyshire
Curse you Paul!!!! :D
Was in John Lewis in Cambridge yesterday late afternoon, your thread got me having a look at an X100S. Had a brief play with it and it's just a gorgeous thing to hold and use. Like you I'd prefer interchangeable glass but what a wonderful camera the 100S is.
Ken Rockwell's site has some fabulous images taken with the 100S too. :^
pmac
14,252
298
Curse you Paul!!!! :D Was in John Lewis in Cambridge yesterday late afternoon, your thread got me having a look at an X100S. Had a brief play with it and it's just a gorgeous thing to hold and use. Like you I'd prefer interchangeable glass but what a wonderful camera the 100S is.
:D
Yep, the X-Pro1 having interchangeable lenses and OVF did it for me, Richard.
Looking forward to receiving it and having a play :^
MeroA
