I am looking I'm behalf of a friend for a flexible speaker cable for under carpet and skirting board install that can be easily bent for inside and outside turns.
The speakers worked very well with Van Damme Studio Blue 2.5mm however it is too thick for under carpet usage or tight turns. So he is looking for a flexible thin discreet cable with a similar generous presentation rather than a drier detailed sound. The van damme is good in the bass at the expense of top end detail and separation.
Thanks for any suggestions
