Amp for KEF LS50 Meta
mattpitts74
6
Hi there, this is my first post here, so please be gentle. I have recently aquired a pair of Kef LS50 Meta speakers and I'm looking for a better amp to pair with them. My current old amp is a NAD D3020. , I have now tried several other amplifiers with the Kefs including:
Rega Brio
Audiolab 6000A Play
Powernode
NAD D3020 - my current amp
So far I have preferred the Rega, but would like to try one of the more powerful Rega amps.
Also, these speakers often get paired with Arcam amps, although their current models are out of my budget there seem to be several used models that might suit the Kefs such as the:
Arcam A85
Arcam FMJ A39
Other used options I have been considering are:
QUAD 405-2 or larger
Linn LK140
In reality, I'm in a pretty small room of only 4m x 4x and play at relatively low volumes of 65-70dB. So interested to hear people's ideas and views on any of these.
ChemMan
ChemMan
2,669
1,760
Brussels
Steve
I have the LS50 with an Arcam A39. It sounds good. I've put four or five amps with them and they always sound good, but I'd probably steer clear of some of the basic Class D designs like the power node and NAD's less expensive stuff. I'd pass on the Linn as well.
I find they are somewhat power hungry and while not all watts are created equal in the world of HIFI amplification, I would try to find a 100W or more. With that said, my 60W tube amp makes them sing.
Jezzer
Passionate
9,844
1,278
Uxbridge
Jezzer
I used to have an A85 about 20 years ago and my memory of that amp is of good power and refinement but perhaps a little laid back for the LS50 Meta (which I also had). I think a pairing with one of Rega’s more expensive amps is a good shout - they tend to have a punchy and fast character. I would also put Simaudio on the list. Then again, if you want smoothness then Arcam is a good shout!
nak
580
717
123
Mansfield-ish
I had a very brief demo of the Kef's once. The amp used was a Musical Fidelity M2si. I'd never heard either before but they seemed to work well together.
uzzy
Grumpy Old Git
8,241
4,108
NN38TA Northampton
The Metas have an efficiency of 85db and an impedance load that drops to 3.5 ohms.
Personal view is save your pennies as all the changes above are IMO sideways steps but not a step to significant improvement.
Look to buy something like a Krell KSA 80 or 100 or how about a HaflerDH200 or 220 ? - These all will handle below 4 ohms. The bargain choice is the Hafler IMO (the Halfer drove my Gale 401s to deafening levels without complaint) they sound great and cost about £200 to £250 second hand - then match it with the preamp of your choice (I use an Audio Research SP9) and in my view this combination would wipe the floor with any amp you can buy for up to £3 or £4k or more (let's put it this way I trialled a pair of EAR 509s and they did not offer enough to make me want to change).
Iceman 16
2,071
2,483
Swansea
His budget is £500 - £1000 and those Krell ksa I think is worth more than that and still need a pre.
Reactions: Rockchild
Rockchild
Formerly Radiant Red 🎶
10,024
12,918
Launceston UK
Jonathan
Uzzy, have you heard the combination your suggesting with the Kef’s?
Rockchild
10,024
12,918
Launceston UK
Jonathan
The Arcam a39 is more than capable of driving the Kefs as suggested. There are many modern amps out there which will also drive them with ease. The trick is to get the synergy right.
Reactions: Iceman 16
t1no
1,172
718
North West
What if you went with a used Kef LS50 wireless (active speaker) around 1K and sold the Metas to pay for them. Same speaker no separate amp to worry about? 🤔
chofsaty
