The stunning new Anthem MRX710 is now available - order now for pre-Christmas delivery!
http://www.audiologica.co.uk/anthem/anthem_mrx710.html
[h=1]The Anthem MRX710 is Anthem's best receiver to date, building on th excellent Anthem MTX700 it takes performance, flexiblity and reliablity to new heights at a bargain price[/h][h=1]
[/h][h=1]Why choose an A/V receiver? With an A/V receiver, everything you need to drive a music and home theater system is contained in one component. They are a space-saving, cost-effective alternative to separates (i.e. a preamplifier, A/V processor and separate external power amplifier). Anthem MRX receivers continue to win awards for their sound quality and ease of integration, and best of all, include ARC™—the Anthem Room Correction system. Read more about this exciting technology below.[/h][h=1]
[/h][h=1]Do I have options? With Anthem you always have options. You can purchase award-winning Anthem separates: a power amplifier (or multiple amplifiers!) to drive your speakers and an A/V processor to select the source (i.e. DVD, Blu-ray player, etc.), decode surround sound, control volume, manage bass, process and/or down-convert video content and send it to the TV/display, send audio to the amp(s), send music to other zones in the house, and control other system devices.[/h][h=1]Either way, you can’t go wrong. It comes down to preference and budget. However, paired with Paradigm speakers, MRX receivers do it all! Now in their second generation, they are a simple, direct and economical route to outstanding music and home theatre[/h][h=1]
[/h]
PREAMPLIFIER
Maximum Output (<0.1% THD) 3.5 Vrms, subwoofer channel 6.1 Vrms
Frequency Response (2 Vrms Output) 8 Hz to 28 kHz (+0, -0.25 dB)
Frequency Response, Analog-Direct Mode (2 Vrms Output) 8 Hz to 50 kHz (+0, -0.25 dB)
THD+N (2 Vrms Output) <0.03%
S/N Ratio (2 Vrms Output, IEC-A Filter) 102 dB
L-R Channel Separation (Analog Input, 1 KHz) 96 dB
PREAMPLIFIER + AMPLIFIER
Frequency Response (Full Power Output) 10 Hz to 30 kHz (+0, -0.5 dB)
THD+N (1W Output) <0.04% (20 Hz to 20 kHz)
S/N Ratio (Full Power Output, IEC-A Filter) 101 dB
AMPLIFIER
Maximum Continuous Output Into 8 Ohms, 20 Hz To 20 KHz, 0.1% THD:
MRX 710 120 W (2 channels driven), 90 W (5 channels driven)
MRX 510 100 W (2 channels driven), 75 W (5 channels driven)
MRX 310 80 W (2 channels driven), 60 W (5 channels driven)
POWER REQUIREMENT
120 V Version: In countries where the line voltage is 120 V, this product operates from a single phase AC power source that supplies between 108 V and 132 V at a frequency of 60 Hz.
220-240 V Version: In countries where the line voltage is 220, 230, or 240 V, this product operates from a single phase AC power source that supplies between 198 V and 264 V at a frequency of 50 Hz.
CONSUMPTION
Maximum 500 W (MRX 710/510), 400 W (MRX 310)
Standby (Default ECO Mode) <0.3 W
Standby IP Control Enabled 2.0 W (1.8 W if network cable is not connected)
Standby HDMI Bypass Enabled 5.6 W
Standby IP Control And Standby HDMI Bypass Enabled 6.6 W
DIMENSIONS
Height 6 1/2 in. (16.4 cm) including feet, 4 rack units with special rack mount
Width 17 1/4 in. (43.9 cm)
Depth 14 5/8 in. (37.2 cm)
WEIGHT
MRX 710 30.8 lb (14.0 kg)
[/h]
- Superb high-quality amp performance includes Anthem’s Advanced Load Monitoring to keep a constant eye on output.
- ARC™ 1M, an enhanced version of Anthem Room Correction ensures the speakers’ award-winning sound isn’t lost in a less-than-perfect room situation.
- Outstanding power – 7 channels in MRX 710 and MRX 510; 5 channels in MRX 310 (see Technical Specs section for power output).
- More HDMI inputs! 7 + 1 = 7 rear inputs and one front-panel input on MRX 710 and MRX 510. 7 rear inputs on MRX 310.
- Dual HDMI outputs.
- 4K Upscaling and Pass-Through.
- HDMI Audio Return Channel.
- Faster HDMI switching.
- Up to 20 input configurations.
- Software updates via the USB port.
- More robust control: IP and RS-232 control drivers for full integration with automation.
- Remote control apps for iOS (Apple) and Android.
- Larger, easier-to-read on-screen menus and improved status displays.
- Dual speaker configuration.
- Speaker crossover now adjustable in 10-Hz Increments.
- Optical, coaxial and analog inputs send 2-channel music to Zone 2.
- Bi-amp the front Left/Right speakers with MRX 710 and MRX 510.
- Power consumption in standby mode: <0.3 W.
PREAMPLIFIER
AMPLIFIER
POWER REQUIREMENT
CONSUMPTION
DIMENSIONS
WEIGHT
