Anyone got a Cable Staple Gun I can borrow...
Tony_J
Gone fishin'
19,635
18,394
I bought one of these from Amazon:
Upholstery Staple Gun Heavy Duty, TOPEC 3-in-1 Stapler Gun with 600 Staples, Manual Brad Nailer Power Adjustment Stapler Gun for Wood, Crafts, Carpentry, Decoration DIY https://amzn.eu/d/gJ3q5x7
Does U shaped staples as well as brads and normal staples. The nose is broader than the Farnell one, but the price is right!
Reactions: garn63
Nestor Turton
Nestor Turton
1,852
3,514
Nowhere in Particular
You could contact Skirting 4U https://www.skirting4u.co.uk/ who have some innovative ways of hiding cable.
If you are buying Ethernet cable then I’d thoroughly recommend https://www.cablemonkey.co.uk/2683-bulk-network-cable - they will make sure you have fully qualified cable. Cable Monkey is Connectix shop. Connectix is a manufacturer. They will also supply patch panels and everything else you need to configure and install your own local area network. They are subsidiaries of BT, And I bought my Cat 6a LAN from them.
parcelmonkey
10,955
7,133
Dover - Kent
Ade
Sorry for the shorter response yesterday as I was out.
However, done a search and this one might work.
https://www.bes.co.uk/electrical/ca...XgSRdWZIokfIG61bThTmD7UsqnZdvUlkaAmBaEALw_wcB
Not too expensive either.
DG…
That's a good price! How are you going to make joins, if you're butt-jointing at corners it will get messy as you'll have to cut the trunking up.
Screwfix do micro-trunking although not as slim as above it's half moon shaped which is over paintable and supply joining pieces for a seamless fit. You don't say how slim?
DiggyGun
DiggyGun
545
756
UK
They don’t do caps or corners for this size. But as it is quite small, mitre corners would be easy and neat with a junior hacksaw, for example.
But if you want cap and corner pieces, you would need the larger trunking. The smallest size for this would be the 16x16mm which is quite a bit bigger.
https://www.bes.co.uk/internal-corner-for-mini-trunking-16-mm-x-16-mm-10901/
DG…
Reactions: parcelmonkey
