Anyone replaced a Class A amp due to power use? Suggestions for replacement?
yoda900
4,008
262
163
Cheshire
Don't know what your budget is but the Emilen Audio D-Block Mono Power Amplifiers are Class D but sound like a VERY good Class A/B.
Having tried them I could happily live with a pair rather than my normal amp that draws 170W when switched on up to 840W when pushed hard. However you would be deaf or have the Police knocking before it hit that level. You would not hear the Police ;) anyway .
  • Haha
Reactions: Snoopdog
Psilonaught
3,374
1,831
Saffron Walden
I expect many members here have air con being in various countries of the world . no doubt that consumes a lot of electricity . music helps mental health and if its class A then happy days !!
I also have air con in my listening room, integrated into the ceiling. I probably only use it a few months a year. I also have 14 solar panels and a glycol solar water heater so all in all my power usage isn't bad....
...then our heated swimming pool ruins everything and in fact our power bills are astronomical lol.
I'll get my coat...🫣
cynix
239
72
43
Scotland
Perhaps a better way to look at it is not to consider the hifi power use in absolute terms but to compare its relative power use to the alternatives that I'd otherwise be spending my time on. Using my AV system + projector to watch a movie or my PC for gaming, both of which use around double the power of the hifi... so in that respect using the hifi instead of either of those options is actually a significant power saving. :D
The Roksan Capsian M2 power amp looks interesting, will look out for a used example of that just to hear what an alternative amp is capable of.
THOMO
911
207
58
Western Australia
I borrowed a latest Purifi Class D.They sound good in some ways and can see how some people might like them.They certainly sound very clear and detailed and they do not seem to have the peculiar haze or swimmy/phasey soundstage I have heard in earlier Class D amps.However the more I listened the more I disliked it.There was very poor musical cohesion and flow and the soundstage was a bit flat and lacking centre focus and depth.In a way it reminded me of the sort of resolution and clarity I hear from my Bakoon amplifier but without the imaging or musical connection I get from that amplifier.
So I would recommend Bakoon for an efficient and cool running amplifier with outstanding clarity and musicality but they are a bit like valve amps in that they really only sound their best with genuine 8 ohm speakers.
Andrei
1,440
433
118
Napier
Andrei
Thanks for the comments and suggestions.
I think I'll keep an eye open over next few months for a possible alternative and at least give a class AB power amp a try.
You can get Class AB that are fairly large Class A Bias. But Plinius and PureAudio do amps where you can choose the level of bias. Low for movies or summer, high for winter or critical listening.
cynix
239
72
43
Scotland
Yes, that was my experience with the Class D amps I've tried (a Wadia and a Teac, think I said Sharp in my original post but I meant Teac). At first I wasn't too sure, they sounded different but like anything else it can take time to get used to a change. But the more I listened the less I liked them and within the week I was sure they weren't staying.
I guess another possibility is to stick with Class A but find a lower power amp, maybe a 40w Class A would only draw 150w or so from the mains and as I don't play things too loud that would likely be fine.
garn63
9,723
12,530
N. Wales.
Mark.
I used to solely use Class A amplification. Presently I am using NVA which I like very much...and you might too ?
Class A/B 60 watts. Should tick your boxes & of course you can try it in your system before committing to buy.(y)
MotherSky
Introspective onanist
1,409
1,031
Shropshire
Proper Class A will draw the same power from the wall regardless of volume - I am happy to be corrected on this, but as I understand it, bias/standing current would be the critical figure (P=VI) MH
Reactions: hiesteem
Jules_S
Are we there yet?
2,406
Southampton
Jules
I appreciate that I'm a bit of a Class-D fanboy, but I'd just say be mindful not to associate what you experienced with all Class D amps - they are absolutely NOT all the same (Just as all Class A or A/B are not all the same).
I'm currently auditioning an Audio Research Class-D amp (yes, I know, heresy!) and it has an astonishing ability with image focus and soundstaging. As we all know, synergy between components is equally, if not more, important than individual performance. An unsympathetic partner will not show up the amp's best qualities.
My previous Gato Class-D amp was a superb match with my Q Acoustics Concept 500s but not quite as good with the Martin Logans, whereas this Class-D Audio Research is really doing the business with them, and it's less powerful than the Gato so it's not all down to grunt. If it was, the MF kW550 that's also currently in residence here would wipe the floor with it... but it absolutely doesn't.
cynix
239
72
43
Scotland
Yes, that's correct. The logic is that my current Class A amp is a huge 80w beast drawing around 300w from the mains, but as I don't play things all that loud maybe a 40w Class A amp would meet my aim to reduce power use while retaining that Class A sound.
Reactions: hiesteem
cynix
239
72
43
Scotland
Yes, quite true.
I was tempted by the Nord NC500 in the classifieds recently and if it had been a little cheaper (thus allowing me to move it on at less of a loss if/when I didn't like it) then I'd have given it a try.
Reactions: Jules_S
uzzy
Grumpy Old Git
8,238
4,096
NN38TA Northampton
Well the money you will save (unless you have the amp going 12 hours a day) may well be a minor amount compared to the cost of changing the amp I have a Class AB amp heavily biased to class A - I did try a Nord Class D and it just lacked the drive and mid range detail of my current amp. Funniest was after I had set it up and put on some music the missus asked me what was wrong with the hifi.
I had it in the system for two weeks to ensire it has a fair shot. After two weeks I slotted the old amp back and it was a great relief .. it was head ans shoulders better overall. Don't get me wrong - for the £1300 or so new that the Nord amp was it is great value for money and I am sure is as good or better than any other amp you can buy for a grand new but it was not my cup of tea and the old Hafler remains (I still have a hankering to change the amp and keep trying different ones but have yet to find anything I can afford, that comes close let alone beat it .. want to try a Prima Luna but will have to get bigger attenuators perhaps if I do lol)
Reactions: Sonofsun
hiesteem
peacebro
1,291
1,018
133
Pete
Don't overlook Class D. The latest offerings, particularly those based on Purifi's Eigentakt technology, are pretty amazing. Look for ones that don't just buy in Evaluation Boards, look for ones that build under licence after tweeking the circuit and using superior components. NAD is, the main player, although I believe that T&A are working on a Purifi amp. . I chose the NAD M33 out of the dozen amps I home demo'd over a prolonged period.
I would add Jeff Rowland class D amplifiers to that list.
hearhere
985
773
113
Portsmouth, UK
Peter
Thanks. I wasn't aware that Jeff Rowland used Purifi Eigentakt modules in any of their amps. although they obviuously use another Class D technology in some units. Could you direct me to any Eigentakt-powered amps from JR? Or any other maintream amp builders that offer Eigentaky-based amps. Thanks. Peter
hiesteem
peacebro
1,291
1,018
133
Pete
T+A use the purifi Eigntact in their A200 stereo and m 200 mono power amps. I don't think Jeff Rowland use the Purifi modules, I mentioned it as it's an impressive build and sound quality. Especially the 535 power amp.
TheFlash
Also available in pink
12,501
8,364
198
Nigel
I hope you have it switched on for less than half an hour per day! Have you thought of replacing it with an amp that sounds as good but consumes a fraction of that? Then you could listen as long as you like with a clear concience - and a low electricity bill?
He might use a 100% renewable energy tariff like some of us do..
hearhere
985
773
113
Portsmouth, UK
Peter
Thanks. I thought it was T&A that had introduced Purifi into their range, Unfortunately if you want T&A to supply the features of the NAD M33, one needs 3 boxes instead of just one and even then there are features such phono stage, room correction DSP, headphone out are omitted.
Reactions: hiesteem
russell2010
18
Barnet
Russell
2nd system: replaced ATC P1 with Nord NC252 to power ATC SCM11s. Works for me. ATC power amp was an immovable power-hungry beast.
newlash09
3,095
2,793
44
India
Y.Manohar / mike
I've been typing for close to 2 hours. Only to loose it all as my tab has a mind of its own
  • Haha
Reactions: uzzy
puresse
