Ariston Transcription TT
D
Dayvan cowboy
I posted previously regarding a rega rp1 so I can spin some old vinyl , but just realised I had this in my loft from back in the day . I can't find much info on it but I remember it cost £349 back in '86. It definitely needs some tlc but I'm wondering if spending 200 on this and getting a new cart fitted and getting it serviced is the way to go ? What do you wise old fellas thing
She's a heavy beast
/monthly_2013_12/image.jpg.35fb7702ce67e9cd46c2839c864e5828.jpg
/monthly_2013_12/image.jpg.cab14b0a6a4ba039256fe301a8612f02.jpg
/monthly_2013_12/image.jpg.11320dd5f06b301c8116ce538fdca73d.jpg
SergeAuckland
Certified Measurist
18,747
1,922
Bury St Edmunds, UK
Serge
Thanks serge , what's the stub decoupling btw
Behind the arm pivot, there's a short piece of tube on which the couterweight sits. That's the stub. The stub is usually decoupled from the main arm by some soft rubber in order to reduce the arm's effective mass at audio frequencies. This rubber often goes soft and the stub droops as yours seems to have done. Usually the rubber decoupling surrounds a thinner piece of metal or plastic to provide some additional strength to the stub, and if the counterweight is abused, that thinner piece of metal or plastic can get broken or bent, but it's not hard to make another out of plastic or metal rod.
S
D
Dayvan cowboy
Oh I see , no this is the design of the arm serge it's always drooped :)
bandit pilot
Comfortably Numb
15,300
2,666
North Nott's
Rick
New one on me. Very weird.
Do you feel it would cost £200 to get it working? £20 ota for a new belt, and as much as you want on a cart I suppose, but going by the prices of very nearly new carts that have been popping up on here all week, I would say you could comfortably do it for less.
D
Dayvan cowboy
What's sort of cart should I be looking for rick any pointers ? Well as I say assuming it needs a service and a rewire of arm but I'm guessing I would get a little change to buy some vinyl maybe :)
Humpty was pushed
2,415
142
Lancs, GB
Vote here for Ortofon 2M Red, about £85. Fitted one a few weeks ago and have been listening to a lot more vinyl since. Tracks quietly through minor damage on old vinyl, which might be a relevant skill in your case.
Was one in classifieds for £60 a few days ago.
bandit pilot
Comfortably Numb
15,300
2,666
North Nott's
Rick
It's not certain to need a rewire, try it out.
Cart wise, something like this http://www.hifiwigwam.com/showthread.php?98660-Ortofon-2M-Red-Brand-new-£60-inc-P-amp-P maybe? This one has gone but this kind of cart is not uncommon and a good saving on a boxed one from the shop. You could also put a wanted ad up. I bet there are members here that might even give you a cart for free. ;-)
That deck you have would no doubt be double that rrp now. Well worth keeping IMO, and probably superior to the other one you're looking at.
SergeAuckland
Certified Measurist
18,747
1,922
Bury St Edmunds, UK
Serge
New one on me. Very weird.Do you feel it would cost £200 to get it working? £20 ota for a new belt, and as much as you want on a cart I suppose, but going by the prices of very nearly new carts that have been popping up on here all week, I would say you could comfortably do it for less.
New one on me too! That arm I think was made by Jelco for Ariston, typical of the OEM arms of the era and all the ones I've ever seen have had the counterweight stub in-line with the main arm, with at very most a tiny droop if the decoupling rubber was a bit soft.
Agree also with the comments that the arm may not need a rewire if there's continuity from the cartridge pins to the phono plugs.
As to cartridges, you could also try a Goldring 1042, should work well in that arm.
S.
D
Dayvan cowboy
Thanks guys , I'm going have a little play tomorrow get it cleaned up take it apart and see whats what ..
rmsshipbroker
5,600
160
Yorkshire
Steve
Are we having a sweep to see how many screws are left over when you get it back together? :p
Nice to see a turntable being put back into action. :^
biker boy
1,131
25
78
Nottingham
Doug
If you have not got the original manual check out Vinyl Engine you should be able to down load it from there. The arm is a Jelco, and the level of droop you have is way out and will need attention such as has been suggested earlier. You have got a really nice deck that with a little TLC should be good for a good few years.
http://www.vinylengine.com/
D
Dayvan cowboy
Interesting after doing some research last night , I naively thought in my youth that ariston was a Japanese made tt , I was surprised to find out it was the fore bearer to linn ...
Might be worth investing some time in after all
D
Dayvan cowboy
The rubber mat is a bit grubby , what's are the pros and cons of rubber vs felt ?
bandit pilot
Comfortably Numb
15,300
2,666
North Nott's
Rick
I cant answer that specific question, but mats do sound different to me. I use a 5mm achromat in place of rubber or felt because it improves the bass no end in my system.
Did you do any research into that flaccid weight yet? That don't look right. :nup:
kelirich
