I'm using a TVC passive preamp to attenuate the analogue signal between my DAC and headphone amp. This might seem odd, but the unbalanced output voltage of the DAC is 4Vrms (sic) and the input sensitivity of the headphone preamp is 300mV. I would imagine that the headphone input would be saturated with such a high voltage signal.
The DAC's analogue output does have (digital) attenuation, but I prefer to keep the output as high as possible so as not to compromise the signal.
My question is this. Without using a multimeter, is it possible to estimate the voltage put out by the TVC preamp for any level of attenuation applied? The attenuator on the TVC preamp moves through 24 steps, from absolute attenuation, then 52dB of attenuation, 50dB and so on up to 0dB of attenuation.
If it is possible to estimate where the attenuator should be set on the TVC so as to allow a maximum signal voltage of 2V to be passed to the headphone amp, I imagine matters would be improved. Common sense suggests it should be set half way, but I know that these things don't necessarily work in a common sense manner!
Many thanks,
Many thanks,
