Auditioning speakers
Musicraft
HiFi Trade
Jun 18, 2008
8,123
397
113
Derby
Definitely not! There is so much more to a speaker than bass.
Yes, it will be noticeable but for all the wrong reasons.
I disagree. As I've said before with all things being equal a subwoofer is the most important component. Ideally frequencies up to 90Hz should be unburdened from the mains and this LF burden passed on to a subwoofer to deal with.
I believe to achieve 'realism' requires power and even if the mains go down to 20Hz a subwoofer should still be incorporated because in my experience a subwoofer can inject power into and energise a system like no other component can.
The goal is to effectively align, calibrate, dial in a subwoofer so that the subwoofer integrates seamlessly with the mains and disappears into the soundstage with a deep, sharp, tight fisted, fast and powerful punchy sub bass.
Eg. system below featuring KEF Reference 3's and dual JL Audio Fathom f112 v2's , JL Audio CR-1 active subwoofer crossover has a crossover point set @ 90Hz -
No power. No depth. No depth. No body. No body. No soul to the sound.
Reactions: rdale
Rockchild
Formerly Radiant Red 🎶
10,024
12,918
Launceston UK
Jonathan
What happened to clarity and texture? In your photo, those speakers are designed not to have to use subwoofers and at the price they are, why should or would you need to spend extra.
I’m not saying that subwoofers are not a benefit but at what price.
Reactions: hiesteem
Friendly Ghost
125
75
Antwerp, Belgium
Casper
I understand that better speakers will give the most benefit.
I do appreciate the dealer bringing it up, it is not because of personal gain for him. The sub he was mentioning would be 1500€, where I am considering to spend a lot more on speakers.
I'll need to look up how REL subs work though, as there does not seem to be any frequency filtering involved (the speakers keep playing the low frequencies)
Reactions: hiesteem
rdale
2,443
1,339
178
Gran Canaria, Spain
Richard Dale
I use a pair of REL TX5 subs with a pair of standmount speakers, and even these second from the bottom of the REL range have seriously clear powerful bass in a small to medium room. As well as the bass, subs also improve the midrange solidity, texture and imaging. I personally believe pairs of subs are best, along with acoustic treatment in the form of bass traps to alleviate room modes.
Reactions: deggie
Amormusic
2,686
1,929
168
UK
I spent quite a while and tried quite a few different speakers on the end of my amp around Christmas time. My original request was floorstanders - the dealer threw me a curve ball and stuck some Harbeth C7ES-3 XD standmounts on the end...
Wow! That is one amazing pair of speakers, and one you should definitely have a listen to.
Reactions: hiesteem
DomT
8,274
6,073
Ericeira Portugal
Dom
Thanks for all the concerns, I will offcourse demo at home before buying!
A curveball by one of the dealers on Friday: it might be a bigger improvement to include a sub, then change to floorstanders.
What are your thoughts in this? I hadn't considered a sub, but can understand that it might have a big impact.
I would think that upgrading to better speakers would be a first step and a sub can follow at a later stage.
Maybe some wammers are happy with their subs but I always have heard the speakers and sub separately rather than having an integrated sound. I would just find a decent pair of speakers that you like and avoid subs as it just adds an unnecessary complication.
Musicraft
HiFi Trade
Jun 18, 2008
8,123
397
113
Derby
With the mains unburdened of frequencies of up to 90Hz there is less compression distortion, current is not being sucked out of the amplifier at LF's, etc.
As I've said before bass is foundation of sound and the stronger the foundations are the better everything else above will be supported. Clarity, texture, etc. can all greatly improve irrespective of the mains. A subwoofer is the most important component -
Dual JL Audio E112's supporting Tannoy Arden Legacy satellites
Dual JL Audio Gotham g213 v2's supporting McIntosh XRT2.1K satellites
Reactions: Tarzan and tuga
Musicraft
HiFi Trade
Jun 18, 2008
8,123
397
113
Derby
A sub/sat pairing becomes an unnecessary complication and a distraction due to improper integration. The goal is to effectively align, calibrate and dial in a subwoofer so that the subwoofer integrates seamlessly with the mains and disappears into the soundstage with a deep, sharp, tight fisted, fast and powerful punchy sub bass.
Reactions: tuga
hifinutt
15,485
3,791
midlands , , United
phil
oh my gosh ... using subs with ardens !!! i only use eatons and they certainly dont need subs .. however rick you are more experinced than I in these matters !
DomT
8,274
6,073
Ericeira Portugal
Dom
The fact that a sub needs to integrate, by definition, is a distraction when there are speakers that you sell that are perfectly fine without a sub woofer. It’s also another box in the room that may need to be placed in an inconvenient location. Have you seen the OP’s photos of his lounge? He has enough challenges with the room as it is.
Rockchild
10,024
12,918
Launceston UK
Jonathan
Agreed. The fact that a 12k floorstander speaker needs a sub is a red flag or room is wrong.
No problem having subs but a speaker of that sort (Kef) is designed to run without.
Rockchild
10,024
12,918
Launceston UK
Jonathan
Yes Rick, we would all love rooms like that but we are in the real world.
The dealer that recommended subs to the op best get round there then and sort 😊
Musicraft
HiFi Trade
Jun 18, 2008
8,123
397
113
Derby
The quality of LF and possibly also the extension and the overall performance of the system can be improved with a subwoofer supporting the system.
Btw, so far we've successfully by managed to incorporate sub/s into all kinds of environments. eg. SCM50ASLT's and with a C4 Sub in the back right corner in the packed living room of a terrace house. Complications and distractions all eradicated through the proper and diligent use of abracadabra :) -
Musicraft
HiFi Trade
Jun 18, 2008
8,123
397
113
Derby
Sorry to say but even though those speakers have good LF however they don't have the extension and also are not capable of producing anywhere near quality of LF's and ultimately are not as capable of supporting the system as a whole as well the Fathom f112 v2's.
Rockchild
10,024
12,918
Launceston UK
Jonathan
You can always improve on any Speaker Rick but at what cost.
Going back to the ops original dealer suggestion, don’t you feel that his current speakers would be the weak link if using a sub?
If the dealer hasn’t visited or heard the system in his room, I fail to see how recommending subs would be even suggested.
We will all agree to disagree but well integrated speaker drivers are designed to work in all areas with its given cabinet design.
Of course a sub can bring something to the party but I’m not convinced of your theory after spending time with various well known designers.
Reactions: hiesteem
Iceman 16
2,071
2,483
Swansea
I have these KEF’s and for the size of my room I don’t think need a sub. Their bass is perfectly fine for me and it can thump on my chest and rattle some of our furnitures. And I’m not a bass nut or a young spoiled brat that always impress friends with room shaking bass.😀. As you’ve already mentioned Jon home demo is a must. 👍
uzzy
Grumpy Old Git
8,241
4,108
NN38TA Northampton
I have been in the game for many years. I love bass. I have never had a bass sub. I chose speakers that did it for me without a sub.
Now I understand that there are space constraints on speaker size but even having said that my old Gale 401s many years ago were not large, they did not object to be being pushed up a against the wall and they produced a great bass response (some would argue that their bass response is even better as it is a sealed box so no port problems to deal with).
For me personally I doubt I will ever use a Sub as the faff factor is beyond me at my advanced years ..
Reactions: Rockchild
tuga
12,723
5,179
Oxfordshire, UK
Ric
As @Musicraft explained adding subs has four advantages:
  • flatter response at the listening spot
  • lower harmonic distortion in the bass
  • lower intermodulation distortion in the range cvered by the woofer
  • higher max SPL
Reactions: Musicraft
deggie
7,027
2,676
edge of birmingham
keith
Well i use a rel t5 with my mabon floorstanders ...its very nice indeed , well integrated you dont know its there .
phil hifinutt has heard it , with no adverse comments ..........phil may well comment later.
Reactions: hifinutt
audimees
