Aurorasound HiFace Pro Bus power pro USB TO SPDIF CONVERTOR 192khz-24bitRRP:£580SOLD
F
flo1984
Aurorasound HiFace Pro two and the Bus power pro comes with the Aune power supply(RRP:£100)https://www.avforums.com/reviews/aurorasound-hiface-dac-bus-power-pro-review.11067/
Input terminal Neutrik USB B type output terminal RCA digital coaxial connector USB Audio Class2.0, ASIO compatible, sampling frequency 44.1, 48, 88.2, 96, 176.4, 192kHz.Price is £250 free postage or collection from London West Ham
resolution 16 to 24 bits Size 97x39x31mm
M2TECH's HIFACE TWO, which is the de facto DD converter for PC audio, is converted to an aluminum die-cast body, and a Neutrik B-type connector is used for the USB input terminal. Furthermore, the built-in filter circuit of the PC bus power power supply has been renewed. This circuit has more advanced noise reduction capability than the conventional hiFace Professional, and smoothes the low frequency ripple component by the conductive polymer aluminum solid electrolytic capacitor, and reduces the noise in the high frequency band and the noise made by the pulse. Equipped with LED for operation check as before.
The internal signal system has been reborn from HIFACE to HIFACE TWO, compatible with Audio Class 2.0 and ASIO, and the new power supply filter circuit has removed stimulating elements to the sound, achieving solid and stable high-quality sound
crxvtec
112
North West London, UK
Hi @flo1984 I'm not getting any sound out from this setup. Could you contact me please? The PC only detects the HiFace 2 but not with the power unit inline. And in either event there's no output to my amp. Thanks.
F
flo1984
yes,sure
brandonfin
