Lovely example of a Bang & Olufsen BeoSound Overture
Beautiful condition apart from some marks on the back.
I have the original manual and literature in the folder. I also have the wall mounting bracket.
Unfortunately I have lost the box with remote and cables! You can still operate it using the buttons but to make life easier, you'd probably want to order a replacement controller via eBay.
Tape cassette play is a little temperamental. If you put a cassette in and start playing it, only one spindle turns but if you FF and RWD then play, seems OK. May need a little work but then I never used it for cassettes.
Tuner works fine.
£150 collected from CB11 or postage at cost.
I also have a pair of Beolab 6000 active speakers which I was going to list tomorrow.
Cheers
Tuner works fine.
Cheers
