Bass bin advice
RobsterD
2,002
131
Southampton
I fancy building a bass bin,one or two depending on size to gel with my horns - think the Lab 12's I had are far to big in my current setup
Interesting array of designs here
http://www.freespeakerplans.com/plans
Any recommendations from the above or shall I just go tapped - anyone got anything surplus at the mo ?
S
scruffybitch
havent a clue, other than to suggest you build it very solidly, else the boxes will shake themselves to bits.
I doubt that fancy woods are required, chipboard or ordinarly ply will be fine
(who disagrees - come on then)
avoid mdf unless you have a good mask, the dust is carcinogenic
MF 1000
Extreme Full Range 😱
6,172
4,731
Caego
Keith
What size cabinet are you looking for Rob .....and how low do you want the bass to be ?
Who Cares?
383
10
23
Are the two essential initial questions that need answering.
Many of those designs have their roots in the world of PA, from decades ago, when high SPLs were desired for concerts and drivers had less power handling capacity than now. Then too, reliable amplifier power was less than now.
Some of those designs are designed, as the info shows, to really only work when stacked as multiples to provide a larger mouth area.
In the main, audio "finesse" was not the aim, just chest hitting bass power.
Domestic bass horn stuff, well, trials and tribulations much in evidence here.
AmDismal
9,277
134
I would propose tapped horns normally - these can be sensibly made to fit in with your ceiling height and volume (loudness) requirements. You may be able to use a fairly small driver (say 10"), which reduces the width of the thing, if you don't need loads of sensitivity and volume. Thing is, they only go up to about 100Hz or so - is that OK?
And I would build with standard ply. Birch is better, but I think I'd prefer 25mm standard ply to 12mm birch, so if budget is a constraint, standard ply is better. MDF is much weaker, and will resonate a lot more.
