On DIYaudio.com in the course of a thread, Joachim Gerhard (quite a well known speaker designer e.g Audio Physic) said this:
So! Can I get these to work properly simply by changing the speaker stuffing of the enclosures considering Joachim's comment above? Currently they are ported with four shallow ports and stuffing is that whispy white synthetic stuff, rough to the touch (know what I mean?) I think it is only attached to the sides..
Can it be calculated or more trial and error?
I have some large kind of PA (could say high-end PA) speakers with dual 15" drivers. An expert in the field (studio engineer, equipment designer) came round to listen to them a while ago and commented on the lack of bass considering the 2x15" drivers. On the back of an envelope and with a tape measure, he said the enclosures were too small (made by an experienced professional cabinet builder but not necessarily a speaker designer) should be nearer 300 litres rather than the 170 litres or so that they are.In closed boxes for subwoofer use i stuff more because you can get an effective virtual doubling of the internal volume. Here glass wool or rock wool is most efficient.
