Bel Canto Audio at Audiologica
Audiologica
Audiologica
1,308
Horsham
Richard Santiago
Audiologica are registered Bel Canto dealers, please contact us for a quote or demo
We are big fans of Bel Canto at Audiologica, bullet-proof build quality and superb reliability coupled with great sound and cutting edge technology make for a sound investmenthttp://www.audiologica.co.uk/belcanto/
01403 789 226
audiologica@btinternet.com
"The DAC3.5VB mkII converts your digital media into music providing maximum system performance and control with the most direct connection to your amplifier. The DAC3.5VB delivers the highest dynamic range and lowest output noise from both analog and digital sources revealing the subtle detail in your music. .The Bel Canto Dual-Differential DAC3.5VB mkII Control Center features a class leading 126dB dynamic range with our proprietary low noise digital to analog convertor core. Including five 24/192 digital inputs, high speed ST fiber and a 24/192 ADC analog input, the DAC3.5VB mkII integrates and controls all of your audio sources including an analog input for a phono preamp or Home Theater Bypass. The front panel features a single multifunction control knob that selects inputs and controls volume level. The DAC3.5VB also includes our new 8 character alpha-numeric display and the ability to control balance, absolute phase and to rename and disable unused inputs.
The foundation of the DAC3.5VB mkII is our jitter-eliminating Master Reference Ultra-Clock circuitry that ensures that jitter from any source is reduced below the audible threshold. The 24-bit digital volume control is completely transparent and accurate throughout the volume range. This precision continues with custom Caddock resistors, class-A output circuitry and low noise power supply components. The heavy-gauge all-steel chassis design prevents mechanical resonance from compromising the audio signal quality.
The internal VB supply is designed to be driven from either our LNS1 or VBS1 virtual battery supply and includes a massive 400,000uF of filter capacitance and a sophisticated ultra low noise isolated switching supply for the analog section. All of this technology prevents power line noise from corrupting the delicate audio signals.
Green, low-heat, efficient isolated power supplies and a finely-tuned analog output stage make possible Bel Canto’s eco-friendly compact designs; Bel Canto music products are fine instruments that are musically satisfying, discrete and sleek enough to fit any room."
hifinutt
15,637
3,951
midlands , , United
phil
agreed , bel canto make fantastic stuff . still using after many years and it just sounds brilliant even though its modestly priced especially the bel canto dac 3.5vbs
Audiologica
Audiologica
1,308
Horsham
Richard Santiago
Various Bel Canto ex demo items available on our Special Offers page
01403 336 339
icb40726
