Best place to buy Schuko and IEC plugs
Maro73
301
6
Arras, , France
EDUN
Hello Guys
I'd be soon trying to build some mains power cords.
Any recommendations for :
1. Which cables are you advising me ?
2. Which schucko plugs to take , and the IEC ones ?
3., Where to buy them ?
I don't know whether the investment for rhodium or other stuff is worth the hype ??
Cheers
clap
1,545
78
Wales
tristan
Maro, knowing your high end kit I would say not to skimp. Personally, good mains cables and plugs gave me a really good upgrade. The soundstage became much better defined, bass was tighter and deeper and a little brightness was removed.
I started off with Mark Grant 2.5 which were great vfm. But, the Furutech Alpha 3 or Oyaide 2 were the top notch cable.
Connector wise , imo, Oyaide are the best. The beryllium copper ones especially. The carbon fibre furutech are very goid but very expensive. Iego are good vfm but not as good as Oyaide. Choose a budget and select from these brands and you won't go far wrong. You can get genuine Oyaide very cheap from Hong Kong.
Reactions: Maro73
Cyclopse
267
4
Maro, knowing your high end kit I would say not to skimp. Personally, good mains cables and plugs gave me a really good upgrade. The soundstage became much better defined, bass was tighter and deeper and a little brightness was removed.I started off with Mark Grant 2.5 which were great vfm. But, the Furutech Alpha 3 or Oyaide 2 were the top notch cable.
Making your own cables. Now a Wammer who has discovered, 'A really good upgrade.' - Discuss
Regards
Cyclopse
daveyu
1,017
56
Furutech, the more expensive the better, Alpha 3 are a good start
clap
1,545
78
Wales
tristan
Oyaide is very expensive guys
They come up second hand occasionally. If you buy from an established wammer it would be fine. Would you pay import tax from Hong Kong? Otherwise, iego are good and cheaper.
hifinutt
16,027
4,290
midlands , , United
phil
furutech , not sure if any benefit with gold or rhodium , just get good quality
I usually get from dave at mains cables r us
Maro73
301
6
Arras, , France
EDUN
HI Guys
I am quite doubful about transactions from Hongkong .. too many fake replicas .
I'm going to browse through mains cables r us
Cheers
35,677
If you really must, I have bought heaps of stuff from these guys:
http://www.tm3connections.com/
Decent, high quality bits at sensible prices.
That said, I'd still rather spend it on Merlot for a proper gain in performance...
The Strat
14,031
Buckingham, UK
Lindsay
Maro - You will have noticed from some of the responses that there is considerable scepticism around here as to the benefit of changing cables etc. I have to say from my experience that there is benefit from at least experimenting (not all changes have been positive) although I must acknowledge that those who claim there is no benefit can point to a lot if not conclusive evidence to support their arguments.All the best.Lindsay
awkwardbydesign
Perfect, apparently.
10,376
2,132
Clive197
27
LONDON UK
Clive
Try SUPRA LoRad 2.5, absolutely great cable, just seen some on the bay for £12.95 per mtr from Divine Audio. TM3 good source for plugs.
markartist
